4x4 not engaging
- Johnniehec
- Thank you received: 56
10 Jan 2012 16:58 #30512
by Johnniehec
Replied by Johnniehec on topic Re: 4x4 not engaging
Going right back to your first post Rswo, how do you know the hubs are not working, how do you know when they do , (1or 2 times out of 10) and how are you trying to engage them 10 times?
Apologies in advance if you think this is patronising but there may be nothing wrong with your hubs.
My understanding is as follows, anyone please feel free to correct me if I'm wrong.
If the Jimny is stationary, with the engine running and you select 4H or 4L the hubs won't necesarily lock. When you select 4WD the vacuum has to slide a collar over the splines in each hub. if either of the splined hub shafts are not in line the collar can't slide so the hub can't lock (and the lamp on the dash will keep flashing?) Only when you move off and there is some movement in the hub and the splines line up will the collar move and lock the hub and the lamp will go steady.
I used to do Offroad training and instruction for corporate customers and manufacturers many years ago and used to have the same "problem" with Defender owners trying to engage the centre diff. When you pushed the transfer lever across to the left you were "requesting" to engage the diff lock, again if you were stationary and the splines in the diff weren't lined up it wouldn't engage and the Diff lock lamp would keep flashing. You could sit there as long as you liked banging the lever as hard as you could and it would make no difference (several owners admitted they had done this, some had even taken their vehicle back to the deales to complain it was broken) as soon as you moved off the splines lined up, the diff locked and the lamp went steady. That's why it was safe and actually recomended to engage the diff lock while moving (as long as you weren't spinning wheels).
Sorry this has turned out to be a bit long winded but I have kinda gone back to basics and it may save you and some others a bit of time and money.
John.;
John.;
- Rswo
- Visitor
10 Jan 2012 17:31 #30518
by Rswo
Replied by Rswo on topic Re: 4x4 not engaging
I have raised and all four wheels of the ground and selected and deselected (ive done this on two seperatate days) and secondly if raised the front and selected then when I turn a wheel manually then both should turn and they don't. Lastly when i jackup one front and select and then tried to turn the wheel that is up then it shouldn't turn. I think this is all correct. The first test of all four wheels up is the test that gave me more results of engaging.
- Rswo
- Visitor
10 Jan 2012 17:35 #30520
by Rswo
Confused are u relating to the posts or a MSG that was sent?
jo king wrote: RSWO YOU HAVE MAIL
- jo king
- Visitor
10 Jan 2012 19:28 #30548
by jo king
Replied by jo king on topic Re: 4x4 not engaging
Private message sorry :whistle:
- Sponnie
- Visitor
10 Jan 2012 19:48 #30551
by Sponnie
Replied by Sponnie on topic 4x4 not engaging
I have Jo Kings kit on my Jimny, faultless so far
- 247sniper
- Visitor
10 Jan 2012 20:33 #30565
by 247sniper
What's kit is that???
Replied by 247sniper on topic Re: 4x4 not engaging
Sponnie wrote: I have Jo Kings kit on my Jimny, faultless so far
