spot lights
- r_ogilvy
05 Dec 2011 09:25 #27286
by r_ogilvy
Replied by r_ogilvy on topic Re: spot lights
Now that's a good question, I want to wire a switch in, do you want them to come on anytime with the switch or with the main beam but with a option to turn then of?
- dirtydogz
05 Dec 2011 09:50 #27288
by dirtydogz
Replied by dirtydogz on topic Re: spot lights
With the the main beam with the option to turn them off.
- r_ogilvy
05 Dec 2011 10:18 #27290
by r_ogilvy
Just a on/off switch would do it between the relay an the switch wire for the main beam would do that.
That's what I will do I think,
- dirtydogz
05 Dec 2011 10:50 #27292
by dirtydogz
Ok mate looks like we are using the same set up.
Thank you.
Baz
Thank you.
Baz
- r_ogilvy
05 Dec 2011 11:12 #27295
by r_ogilvy
What I was thinking aswell the earth triggers the relay then the lights come on.
You could have a switch to light it on its own just by an earth leading to the relay with a switch, I think
- dirtydogz
05 Dec 2011 11:29 - 05 Dec 2011 11:39 #27297
by dirtydogz
You mean earth the switch to the body of the jimny, will save you using the red wire as a trigger on the light socket.
so they come on even if the light are off
Off to work now so let me know how you get on.
Last edit: 05 Dec 2011 11:39 by dirtydogz.
Time to create page: 0.091 seconds
