spot lights
- r_ogilvy
04 Dec 2011 14:04 #27196
by r_ogilvy
spot lights was created by r_ogilvy
im trying to wire spot lights, i have wired them u to the main beam, when i turn the lights of they come on
when i turn the light on (normal lights) they go off then when i put the main beam back on they come on again
:blink: :huh:
- dirtydogz
04 Dec 2011 16:21 - 04 Dec 2011 17:04 #27213
by dirtydogz
Replied by dirtydogz on topic Re: spot lights
Haven't wired my roof lights up yet,:dry: but this is how l will be wiring them.
The trigger is the red wire on the headlight plug.
www.bigjimny.com/index.php?option=com_ku...7&id=15565&Itemid=75
Hope this helps.
Attachment neg2pos.gif not found
Hope this helps.
Last edit: 04 Dec 2011 17:04 by dirtydogz.
- r_ogilvy
04 Dec 2011 19:05 - 04 Dec 2011 19:06 #27251
by r_ogilvy
Replied by r_ogilvy on topic Re: spot lights
ideal working. opposite wiring on the jimny had to us the - not +
that was a good 4hr pain in the ass, :huh:
thanks dirtydogz
thanks dirtydogz
Last edit: 04 Dec 2011 19:06 by r_ogilvy.
- dirtydogz
04 Dec 2011 19:33 - 04 Dec 2011 19:35 #27258
by dirtydogz
Your welcome mate glad to help.
You can thank Renard 38 for this.
Last edit: 04 Dec 2011 19:35 by dirtydogz.
- r_ogilvy
04 Dec 2011 19:58 #27261
by r_ogilvy
any other car i played with its been a simple job, rather than switching all the wires about.
thanks renard38
thanks renard38
- dirtydogz
05 Dec 2011 08:03 - 05 Dec 2011 08:04 #27281
by dirtydogz
Help with this switch and relay set up, if the the trigger is the earth, do l need to run a live feed to the ground on the switch to light it up.
Attachment DSCF1638.JPG not found
Attachment neg2pos_2011-12-05.gif not found
Last edit: 05 Dec 2011 08:04 by dirtydogz.
Time to create page: 0.111 seconds
