spot lights
- r_ogilvy
05 Dec 2011 12:05 #27300
by r_ogilvy
Replied by r_ogilvy on topic Re: spot lights
I'll do a diagram later, I'm gonna use a rocker switch, on/off/on.
One to just have spots on, the off to have the lights off at all time even with the main beam on, and the other (on) for the spots to come on when u put the main beam on, if that makes sense, I confuse my self sometimes!
- r_ogilvy
05 Dec 2011 15:59 #27308
by r_ogilvy
this is how im doing mine, correct me if im wrong anyone??
i think this is correct using a rocker switch, on/off/on
Attachment neg2pos.gif not found
- renard38
05 Dec 2011 18:35 #27319
by renard38
Replied by renard38 on topic Re: spot lights
- r_ogilvy
06 Dec 2011 10:04 #27362
by r_ogilvy
Thanks renard38, nice truck you have
- Sandez
06 Dec 2011 11:25 #27364
by Sandez
There is a problem with your diagram, you have both the wire before and after the switch going to the same terminal, which will complete the circuit, negating the switch.
I thought a 2 mode switch would have 4 terminals, if it is an illuminated one, one terminal for input, output 1, output 2, and earth. Unless the switch you have isn't illuminated.
This is how I would do it:
If you use an illuminated switch on the trigger wire, the switch would work as per normal, but the switch will always be illuminated, as the trigger is an active 12V line. I believe this is due to when the switch is in the off position, output 1 and output 2 are being earthed on the switch (as in a normal circuit these wouldn't be active), causing the light to illuminate.
As you have setup in your diagram, you have both the output 1 and output 2 running off your trigger line, if you use output 2 (bypass headlight switch) then you would be running them off your trigger power, which is your headlight power, therefore I would put the switch on the input line.
Hope its not too confusing.
Replied by Sandez on topic Re: spot lights
r_ogilvy wrote: this is how im doing mine, correct me if im wrong anyone??
- Sandez
06 Dec 2011 11:28 #27365
by Sandez
By the way, Renard's diagram would work as well, but only with a non illuminated single mode switch. A double mode switch would work but as I stated above, I believe it would use the headlight's power which is something you don't want.
Time to create page: 0.176 seconds
