spot lights
- r_ogilvy
06 Dec 2011 12:10 #27368
by r_ogilvy
Replied by r_ogilvy on topic Re: spot lights
Hi, yeah I understand, the problem with jimny is the trigger wire for the main beam is a - negative so a earth can be used, to trigger it, I havnt got a illuminated switch.
So I was gonna use the negatives on my switch, and just break the earths by the switch.
But I can see your point, either way will work for what I can make out without trying.
Tell me if I'm wrong again tho,
- r_ogilvy
06 Dec 2011 12:21 #27369
by r_ogilvy
I understand now tho, I have completed the circuit.
This is confusing!
This is confusing!
- r_ogilvy
06 Dec 2011 12:32 #27370
by r_ogilvy
Ok. Just worked it out in my head. Your correct, and I would like a illuminated switch to be used so I will buy one.
My wiring is crap. I see what your saying, thanks
- dirtydogz
07 Dec 2011 10:36 - 16 Dec 2011 21:51 #27456
by dirtydogz
Replied by dirtydogz on topic Re: spot lights
Ok roof light working with my main beam, l'm happy now at last.
I wired it up the same as in this relay picture, and just add a live from the relay fuse to the ground on the switch.
Attachment DSCF1639.JPG not found
Attachment neg2pos_2011-12-16.gif not found
Last edit: 16 Dec 2011 21:51 by dirtydogz.
- r_ogilvy
07 Dec 2011 13:00 #27467
by r_ogilvy
I'm gonna copy what sandez has done, he's right I think, I'm gonna have a go later or tomorrow,
What other wire have you put else where on your switch dirtydogz?
- dirtydogz
07 Dec 2011 20:55 #27502
by dirtydogz
red wire on back of headlight to power on switch
85 on relay to acc on switch.
add one more wire to fuse run it to the ground on the switch.
Time to create page: 0.353 seconds
