02 4x4 problem
- Waite
15 years 1 month ago #23085
by Waite
Replied by Waite on topic Re: 02 4x4 problem
So does this mean jimny needs a new transfer box.or is there more to it??just noticed front left wheel hub leeking. Help please on both problems.many thanks
- vitara_mad
15 years 1 month ago #23089
by vitara_mad
Replied by vitara_mad on topic Re: 02 4x4 problem
is the hub leaking from behind ???
axel oil seal will need replacing & prob kingpin bearings if its front & wheel bearing if it the rear
- X-Eng Simon
15 years 1 month ago - 15 years 1 month ago #23108
by X-Eng Simon
Replied by X-Eng Simon on topic Re: 02 4x4 problem
On Tarmac, does it happen if you drive in a straight line - or only while turning?
If the latter, its probably just the wind up that people have mentioned - though 10' is a very short distance for it to occur in and it wouldn't normally stop the vehicle.
If it's the former, I would check to see if the front & rear diffs are the same ratio. To do this, put it in 2WD and jack up one wheel. Count the number of revolutions of the prop shaft for one revolution of the wheel.
Alternatively, make a mark (TipEx) on the front and rear prop shafts so that the marks line up with one another. Then, in 2WD drive it in a straight line for a short distance. If the marks no longer line up - then the diffs are different ratios.
front & rear should be exactly the same. Jimnys can have 4.11 or 3.9:1 ratio. It is possible the owner had replaced one diff with the wrong ratio.
Si
Si
Last edit: 15 years 1 month ago by X-Eng Simon.
- goatboy
15 years 1 month ago #23109
by goatboy
Replied by goatboy on topic Re: 02 4x4 problem
Simon,
Don't think he is having problems getting 4th gear, just problems selecting 4 High...
- X-Eng Simon
15 years 1 month ago #23110
by X-Eng Simon
Sorry - I'd mis-read the post - and edited mine to reflect it.
Si
Si
- Waite
15 years 1 month ago #23113
by Waite
it happend when driving in a straight line.did not try while turning.iwill try ratio turn when stops raining. thanks for info si one other thing when in 4h jimny hard to roll when in nutral???
Time to create page: 0.101 seconds
