02 4x4 problem
- goatboy
05 Oct 2011 14:04 #23116
by goatboy
Replied by goatboy on topic Re: 02 4x4 problem
Is there a chance your front diff is just completely seized (i.e. broken)?
In 2WD the front hubs should release and the front diff shouldn't be turning so it wouldn't stop you driving.
Might be worth checking to see if the front diff has any oil in it...
- Johnniehec
- Thank you received: 56
05 Oct 2011 14:06 #23117
by Johnniehec
Replied by Johnniehec on topic Re: 02 4x4 problem
Waite, I agree with Simon it sounds like wind up so there must be a difference between front and back, You've not got different size tyres front and back by any chance have you? even same size markings - different manufacturers or new one end - well worn the other might do it.
If you're talking about neutral on the main gear lever it won't make any diference. If the transfer lever is in 4WD front and back are still locked together.
The following user(s) said Thank You: Waite
- Waite
05 Oct 2011 15:13 #23119
by Waite
Replied by Waite on topic Re: 02 4x4 problem
tyres all same size.same manufactor worn roughly same. noticed back right and front left tyre rotation wrong way.thanks waite
- Waite
05 Oct 2011 15:16 #23120
by Waite
i will look in to it and let you know asp cheers.after ive looked into every thing else might be a while. many thanks
- Waite
07 Oct 2011 14:46 #23209
by Waite
hi si tried as you said in 2wd . 2 turns on back diff. when tryed front diff and prop not turning.????
- X-Eng Simon
07 Oct 2011 15:56 - 07 Oct 2011 15:58 #23214
by X-Eng Simon
Replied by X-Eng Simon on topic Re: 02 4x4 problem
OK. Try removing the front prop shaft ( dead easy). Jack up one wheel and see if you can turn the input to the diff by hand / or turn the wheel and see if the input turns. If not, try it with both front wheels off the ground.
If it turns with both wheels jacked, you either have a locker in the front, the diff has been welded up or it is broken.
If it still does not turn it could be a siezed pinion bearing on diff or its otherwise broken.
Then try turning the output of the transfer box. It should turn freely. If not, problem in transfer box.
Si
Si
Last edit: 07 Oct 2011 15:58 by X-Eng Simon.
Time to create page: 0.101 seconds
