02 4x4 problem
  • Waite
04 Oct 2011 17:11 #23041 by Waite
02 4x4 problem was created by Waite
ok in two wheel drive rear wheels turn freely.when put in 4wheel drive off road. wheels feel like they are sticking like having hand break on.frees some times after driving for a while .put four wheel drive on tarmac. wheels bind up on jimny wont move after about ten feet. impossible to put in 4h while driving will only go in and out of 4h while stationary . help any
  • mcjimny
04 Oct 2011 17:28 #23045 by mcjimny
Replied by mcjimny on topic Re: 02 4x4 problem
Could be transmission wind-up. You can't drive on tarmac in 4wd for this reason, Jimny's don't have a centre diff so when the inside wheel can't slip as it would on loose ground it winds up the transmission.
This explains why you can't progress any further when on tarmac.
Have you only just go the car? or have you driven it on tarmac in 4wd before?
  • Waite
04 Oct 2011 17:48 #23050 by Waite
Replied by Waite on topic Re: 02 4x4 problem
only just got car. good old ebay?
  • mcjimny
04 Oct 2011 18:42 #23063 by mcjimny
Reversing can unwind it if the damage isn't beyond the point of no return.
When it winds up it can be followed by a nice big bang as something gives up.
Sounds like its been done by the previous owner and they've palmed it off knowing that many buyers wouldn't always test 4wd.
  • Waite
04 Oct 2011 19:10 #23067 by Waite
Been having to reverse to free symptom when coming off unmade rd.clicks twice then frees then jimmy runs with out feeling like hand brake sticking in two wheel drive.hope this helps to diagnose my problem.fingers crossed.
  • adamatdraycott
05 Oct 2011 05:01 #23070 by adamatdraycott
Replied by adamatdraycott on topic Re: 02 4x4 problem
Sounds like wind up to me
I have only ever had it once. That was in the snow turning round, as i have to turn round to land on the drive properly.
In reverse with some lock applied the car grumbles, and will stop... back into first and its fine. I tend to try and use hills to reverse in 4x4 especially if i need to steer! Decent amount of snow, a good covering, so its not like the wheels couldn't slip.
I spent time when i was looking for a jimny for someone who wouldn't know it was 4x4. Mine had clearly never been offroaded. The gear stick was very stiff and clunky. Oil change and now i can change easily!
Time to create page: 0.311 seconds
