02 4x4 problem
  • X-Eng Simon
15 years 1 month ago #23217 by X-Eng Simon
Replied by X-Eng Simon on topic Re: 02 4x4 problem
Waite wrote: hi si tried as you said in 2wd . 2 turns on back diff. when tryed front diff and prop not turning.????
Also, when you say not turning, do you mean the wheel turns but the prop doesn't or neither turns?
Si
  • Waite
15 years 1 month ago #23219 by Waite
Replied by Waite on topic Re: 02 4x4 problem
yes front wheel turns. prop does not.cheers
  • X-Eng Simon
15 years 1 month ago #23229 by X-Eng Simon
Try taking the prop off and test as above.
Si
  • Waite
15 years 1 month ago #23249 by Waite
Ok undone prop from front diff. Diff turns by hand wheels do not. Turn wheels by hand diff does not turn. Turn prop on transfer box. Diff and prop turn freely all done in 2wd. Turn in 4wd prop and diff on transferbox dont turn ????
  • mcjimny
15 years 1 month ago #23254 by mcjimny
Replied by mcjimny on topic Re: 02 4x4 problem
The wheels and/or diff wont turn each other in 2wd as the freewheeling hubs won't be engaged. But it's obviously demonstrated that they are all rotating and free.
Therefore it sounds like its wound up the transfer box. :pinch:
  • Waite
15 years 1 month ago #23258 by Waite
hi so when you say its wound up the transfer box do you mean i need anew transfer box.?or can it be repaired.many thanks. as you can see i am a novice at 4x4s.
