Thoughts on building an offroader
- darthloachie
12 Sep 2011 11:06 - 12 Sep 2011 11:07 #21714
by darthloachie
Replied by darthloachie on topic Re: Thoughts on building an offroader
you can also get hardened halfshafts and cv joints from places like DG Tuning
www.dgtuning.com/
exterior axle strengthening trusses www.ora-store.com/
(they also do a mean tubular body conversion called the assassin)
Then add difflocks - ARB or Kamlocker or lockrights depending on budget
with a 4.5" lift you'll fit 33s without too much bother if you are going to tube it
Last edit: 12 Sep 2011 11:07 by darthloachie.
- X-Eng Simon
12 Sep 2011 15:06 #21728
by X-Eng Simon
Replied by X-Eng Simon on topic Re: Thoughts on building an offroader
As has been mentioned, stock axles ae fairly weak. One option might be SJ axles with Vitara Diffs which seem to be a stronger option.
Failing that, Land Rover axles are cheap as chips and a whole lot stronger, without weighing as much as Toyota etc.
The strongest easily available axles are Toyota 80 Series - but they are quite heavy. You've probably already seen my thread here about putting 80 axles on.
Mine cost under £400 and come with difflocks as standard.
Si
Si
- TomDK
12 Sep 2011 15:18 #21729
by TomDK
Replied by TomDK on topic Re: Thoughts on building an offroader
Hi Simon
Do you know how much your 80 axles fitted Jimny weigh ?
Tom
Tom
- X-Eng Simon
12 Sep 2011 17:07 #21734
by X-Eng Simon
Not precisely - but I reckon about 150kg the pair. Front is about the same as a Land Rover, rear the same as a Land Rover Sallisbury. That's about double the weight of stock Jimny Axles.
Si
Si
- TomDK
12 Sep 2011 19:07 #21742
by TomDK
Sorry, didn't make myself clear
I meant the whole car with LC 80 series axles fitted
- X-Eng Simon
12 Sep 2011 19:50 #21745
by X-Eng Simon
My previous vehicle (pictured in my Avatar) based on a Vitara weighed in at 870kg including 2 winches and 37" tyres on Beadlocks. This one will be a bit heavier for various reasons.
I'm aiming for 1000kg but will be happy with 1200kg all up.
The Jimny with all the seats, trim & soft top removed weighs under 900kg which should bring it in at 1100kg fully built up. I'll weigh it when it's finished (I have an Avery Load cell to dangle it from).
Si
Si
