Thoughts on building an offroader
- TomDK
12 Sep 2011 06:51 - 12 Sep 2011 07:21 #21698
by TomDK
Thoughts on building an offroader was created by TomDK
Hi, new guy here
I have been thinking about building an offroader based on the Jimny. It's not supposed to be streetlegal.
As of now I have a few questions:
Are all Jimnys (from'97) coilsprung, or are the earlier models with leafsprings?
How strong are axles, joints etc.? My plan is to use a BMW E30 2.0 engine with auto-transmission.
I know its a bit heavier than the Jimny engine, and longer also. But since this is only for offroad and I'm planning on relocating the radiator, I think it will fit
And, what size tyres are you running for hardcore offroad?
Think I'm going for and EMU suspension, but are 33" tyres too big? Perhaps Simex Jungle Trekker or Interco Boggers
Hope you can help me out
Thanks,
Tom
Thanks,
Tom
Last edit: 12 Sep 2011 07:21 by TomDK.
- vitara_mad
12 Sep 2011 07:18 #21699
by vitara_mad
Replied by vitara_mad on topic Re: Thoughts on building an offroader
all jimny's are coil spring
- mcjimny
12 Sep 2011 07:30 #21700
by mcjimny
Replied by mcjimny on topic Re: Thoughts on building an offroader
for extreme off road i would say the stock axles and shafts are too weak and an upgrade to hilux axles would be sensible.
- TomDK
12 Sep 2011 07:45 - 12 Sep 2011 07:46 #21703
by TomDK
Replied by TomDK on topic Re: Thoughts on building an offroader
Thanks to both of you
I'm not planning on using the body. Only frame/chassis, axles, suspension etc. And then build some kind of rollcage.
Also one of the key elements of the build is that it must not exceed 1100-1200 kg since I can only pull 1800 kg with my car, and I need to transport the offroader on trailer
How much heavier is these Hilux axles?
I thought the Hilux had independent front axle with torsion bars?
Tom
Ps. Sorry for my lack of technical terms in english
Tom
Last edit: 12 Sep 2011 07:46 by TomDK.
- panosd
12 Sep 2011 09:32 #21707
by panosd
Replied by panosd on topic Re: Thoughts on building an offroader
The most common in Greece are the land cruiser 70 axles , nissan patrol axles and mercedes G axles.
take a look to a jimny with lc axles here
mercedes axles here www.jimnyclub.com/forum/index.php/topic,5624.0.html (translate from greek)
patrol axles here pirate4x4.com/forum/showthread.php?t=829727
- TomDK
12 Sep 2011 09:44 #21708
by TomDK
Thank you very much.
But the Link with LC axles are missing
Time to create page: 0.114 seconds
