Thoughts on building an offroader
  • TomDK
12 Sep 2011 06:51 - 12 Sep 2011 07:21 #21698 by TomDK
Thoughts on building an offroader was created by TomDK
Hi, new guy here :-)
I have been thinking about building an offroader based on the Jimny. It's not supposed to be streetlegal.
As of now I have a few questions:
Are all Jimnys (from'97) coilsprung, or are the earlier models with leafsprings?
How strong are axles, joints etc.? My plan is to use a BMW E30 2.0 engine with auto-transmission.
I know its a bit heavier than the Jimny engine, and longer also. But since this is only for offroad and I'm planning on relocating the radiator, I think it will fit :-)
And, what size tyres are you running for hardcore offroad?
Think I'm going for and EMU suspension, but are 33" tyres too big? Perhaps Simex Jungle Trekker or Interco Boggers :-)
Hope you can help me out :-)
Thanks,
Tom
Last edit: 12 Sep 2011 07:21 by TomDK.
  • vitara_mad
12 Sep 2011 07:18 #21699 by vitara_mad
Replied by vitara_mad on topic Re: Thoughts on building an offroader
all jimny's are coil spring B)
12 Sep 2011 07:30 #21700 by mcjimny
for extreme off road i would say the stock axles and shafts are too weak and an upgrade to hilux axles would be sensible.
  • TomDK
12 Sep 2011 07:45 - 12 Sep 2011 07:46 #21703 by TomDK
Replied by TomDK on topic Re: Thoughts on building an offroader
Thanks to both of you :-)
I'm not planning on using the body. Only frame/chassis, axles, suspension etc. And then build some kind of rollcage.
Also one of the key elements of the build is that it must not exceed 1100-1200 kg since I can only pull 1800 kg with my car, and I need to transport the offroader on trailer :-)
How much heavier is these Hilux axles?
I thought the Hilux had independent front axle with torsion bars?
Tom
Ps. Sorry for my lack of technical terms in english :-)
Last edit: 12 Sep 2011 07:46 by TomDK.
  • panosd
12 Sep 2011 09:32 #21707 by panosd
Replied by panosd on topic Re: Thoughts on building an offroader
The most common in Greece are the land cruiser 70 axles , nissan patrol axles and mercedes G axles.
take a look to a jimny with lc axles here
mercedes axles here www.jimnyclub.com/forum/index.php/topic,5624.0.html (translate from greek)
patrol axles here pirate4x4.com/forum/showthread.php?t=829727
  • TomDK
12 Sep 2011 09:44 #21708 by TomDK
Thank you very much.
But the Link with LC axles are missing ;-)
