Minor Electrical Problem ??
15 years 6 months ago #16488 by Johnniehec
darthloachie wrote: what!!!!! they're supposed to light up!!! :ohmy:
LOL :laugh: :laugh: :laugh:
John.
  • Nelson83
15 years 6 months ago #16569 by Nelson83
Replied by Nelson83 on topic Re: Minor Electrical Problem ??
Ive had both of these problems - handbrake light is cured by turning the key back slightly, about 1mm. Dont know what causes it but it seems to happen more during hoty weather. As for the heater lights - i used the bosh the top of the dash until it came on - worked for about 12months, then stopped. So i investigated and changed the bulb - even managed to write a guide for how to do it - see the how to guides :-D ;-)
  • svejk
13 years 10 months ago #57132 by svejk
Replied by svejk on topic Minor Electrical Problem ??
hello all!
i have a g13bb jimny since august 2012.
same problem with the dashboard heater lights :)
first time i drove the car after buing it, for 200 kms i've braked with my turn signals :)
after that, the problem fixed by itself, no bother since
my car was imported from holland, is a dec 1999 make
i noticed that EVERY electrical socket, connector and such is heavily covered in oxide
(note to self, in the spring, unplug ALL and use contact spray with generosity)
in the meantime, i have another issue that forces me to carry a 10mm spanner as keyfob:
my position lights (front and back) and meter illumination stays on no matter what.
re:meter illumination, the small lcd display that goes on with acc/ig goes off normally
only the back illumination stays on, together with front and back lamps.
it's not the steering column switch, as disconnecting it from the socket underneath the steering column won't remove the problem
i suspect that it's a relay that got blocked somehow, but where this could be?
for three days before this, the turn signal relay worked properly/not/properly/not/properly
now i have no problem with the turn lights (when malfunctioned it worked like i had a faulty signal lamp - at first on one hand, then on the other one as well - that was the moment i've realized that it's the relay and didn't bothered to change the lamps)
so, aside from disconnecting the battery + cable every time i have to stop for more than 5 minutes with the engine stopped, what should i do? where to look?
also, i suspect that the car has centralized lock, because i've found the actuator on the back door when tried to solve the non-functioning lock (not solved, works only from inside, on the outside the key won't turn even after copious amounts of wd and jiggling) (in the lateral doors i didn't had a look yet)
any tips as why (if fitted) this doesn't work?
apart from searching for a bad earth/ground... i get a headache only thinking i have to search for something like this. this car's electrical system is a nightmare better left alone...
thank you!
  • jimnybob
13 years 10 months ago #57170 by jimnybob
Replied by jimnybob on topic Minor Electrical Problem ??
i had the side lights comin on when i braked (dash would light up too) and discovered it was a short on the trailer light plug :laugh:
  • GuardianAngel
13 years 10 months ago #57172 by GuardianAngel
Replied by GuardianAngel on topic Re: Minor Electrical Problem ??
I have the handbrake light problem occasionally, but it goes out eventually.
As has been said before, its "character" :dry:
  • svejk
13 years 10 months ago #57187 by svejk
i understand that :)
the problem is that isn't funny at all carrying a 10mm spanner as keyfob and unbolting the battery everytime i have to stop...
Time to create page: 0.098 seconds
