Minor Electrical Problem ??
- svejk
13 years 10 months ago #57354
by svejk
Replied by svejk on topic Minor Electrical Problem ??
definitely, the first thing tomorrow!
again, thank you, guys!
- svejk
13 years 10 months ago #57373
by svejk
removed the fat's guy contraption.
position lamps problem solved :woohoo:
reached inside the dashboard, pulled out at leat 7cm more of cable, connected the player.
works perfectly
so, i 'sspose don't get in the electricals if you have sausage fingers!
or use tools to do the job if your fingers cannot get inside
:whistle:
BIG THANK YOU FOR ALL!
:woohoo: :woohoo: :woohoo:
works perfectly
- Dirtbird
7 years 9 months ago - 7 years 9 months ago #202014
by Dirtbird
Replied by Dirtbird on topic Minor Electrical Problem ??
Just found this it pays to search
www.bigjimny.com/images/documents/changing_the_heater_bulb.pdf
really neat article and will be using it tonight .
Last edit: 7 years 9 months ago by Dirtbird.
- Thank you received: 706
7 years 9 months ago - 7 years 9 months ago #202028
Replied by jackonlyjack on topic Minor Electrical Problem ??
Mine as not worked for ages will have a look
thanks Dirtbird
on the plus side i only have to pull my switch panel 2 minute job
Can anyone tell me the bulb type in heater ? i want a blue one
thanks Dirtbird
Last edit: 7 years 9 months ago by jackonlyjack. Reason: Added a line
- Dirtbird
7 years 9 months ago - 7 years 9 months ago #202078
by Dirtbird
Halfords Blue packaging No 284 W2.3W.
Slip off the green cover of the old bulb and slide it over the old bulb. As for bulb color, you could try an arts and crafts shop and buy some glass paint.
Got it in in about 30 mins after I realized the bulb holder is part of the circuit, there's no wire going into the back of the bulb holder spent a bit of time looking for a wire that does not exist.........
- Dirtbird
7 years 9 months ago #202095
by Dirtbird
Jack I spent about 20 mins looking for a wire to connect to the bulb holder .......there is none the bulb holder has two little nicks in it which are powered when it's locked/clicked into position I don't have pics but you will see. Also, remove the ashtray holder it helps to get your hand up em.....
At long last I can enjoy the pleasure of adjusting my heat
jackonlyjack wrote: Mine as not worked for ages will have a look
thanks Dirtbird
Time to create page: 0.113 seconds
