Minor Electrical Problem ??
- jimny5
13 years 10 months ago - 13 years 10 months ago #57278
by jimny5
Replied by jimny5 on topic Minor Electrical Problem ??
I had my sidelights stay on when key was removed. Turned out the connector for headlamp height adjust was pluged into rear fog and vice visur, easy mistake after body swap.
Found it by pulling fuses. That way you can elimnate diiferent circuits that could be giveing you a live or earth to wrong circuit.
Or by unpluging parts.
Hope you find it. Can drive you crazy trying to think where it could be.
Mike
Mike
Last edit: 13 years 10 months ago by mlines.
- svejk
13 years 10 months ago #57293
by svejk
Replied by svejk on topic Minor Electrical Problem ??
removing fuses didn't solved the problem, i've managed to find that the switch assy from the steering column is ok,
i still think that a relay is to blame, didn't find it yet...
headlamps leveling works ok, same for fog lights....
13 years 10 months ago #57307
by facade
Replied by facade on topic Minor Electrical Problem ??
The brake light and indicator coming on at the rear is usually an earth fault at the rear light unit
All the position lamps are connected to a red wire with yellow trace.
Either
a) This is getting a live from somewhere....
b) something has lost its earth, and is trying to earth out through the position lamps, this means something is not working that should be
ideas
1) is the brake light switch stuck on? This will put the brake lights on (they don't need the ignition on), but if there is no earth at one of the rear lamps it will make the position lamps come on- if the indicator bulb is faulty on that side.
2) the red/yellow wire goes to the radio, has this got joined to the permanent live feed at the radio? Maybe a fault has developed in the radio?
3) the red/yellow goes to the warning buzzer - a fault here?
4) the red/yellow goes to something called ECM on the diagram. As I'm not aware of any Electronic Counter Measures I think this is the main ECU, I've no idea why the sidelights connect, unless it is to tickle the idle speed up a bit to overcome the extra alternator load, this could be faulty.
5) as said already, if a trailer socket has been fitted it is easy for the position light wire to cross over to a live wire
6) the headlights are live all the time, if the headlight wires have somehow connected to the red/yellow this will put the lights on.
Either
ideas
The following user(s) said Thank You: svejk
- svejk
13 years 10 months ago #57342
by svejk
OOOOOOOO!
1)no, everything is fine, sorted out by itself in 200kms after buying it (on the road to home) - i think about a corroded/oxided contact that got cleaned by using it
2) i think this is where i have to search, as the whole bloody thing appeared after i've bought a "CD player" (with SD and usb only) and the fat guy that fitted it installed an extension cause his fingers could not reach the original socket....
on the second thought, i've tried dismantling the radio, but to no success... it's true that i didn't pull out the extension installed by this guy, only the unit...
i have to get it a try soonest possible, tonight is snowing again here.... damn!
3) the buzzer works ok, i.e. even with the switch in the off position, because the lamps are on, it's working when i open the door
4) i have also to check the red/yellow where it connects to the ecm, as i've said, ALL the electrical connections of this car are covered in Al or Cu oxide....
5) not the case here
6) this is also a thing to investigate
thank you!
THANK YOU!
(would it matter to you, to say that suzuki specialists in romania - where i am from/live scratched their foreheads and this was the only answer they could get me in respect of this?)
i can hardly wait for more forgiving weather to start investigating!
fingers crossed, next time i'll post it will be a "success post" :woohoo:
(and please, excuse my non-native english as well)
thank you!
THANK YOU!
- jimny5
13 years 10 months ago #57352
by jimny5
I would say check ya radio first. On mine extension/ adaptor it has different wires you can plug in for different option. Fat guy could have fucked it.
13 years 10 months ago #57353
by facade
Remove the extension lead to the CD player and sort out the connections.
If you dont know what they should be, just cut off the red/yellow striped wire and at least the lights will stay off.
Time to create page: 0.104 seconds
