Minor Electrical Problem ??
  • Bannerbrother
15 years 6 months ago #16353 by Bannerbrother
Minor Electrical Problem ?? was created by Bannerbrother
ive had my jimny for nearly a month now and have noticed a couple of minor things with the electrics, and just wondered if its a common thing or not.
The heater control lights have a mind of there own and only work wen they feel like it.
And occasionaly the handbrake warning light comes on and stays on until turn off the ignition and start it again. (ive checked the fluid level and conection on the hand brake but both seem fine)
not major faults i know just annoying anything anyone can surggest to fix them??
  • NickG
15 years 6 months ago #16362 by NickG
Replied by NickG on topic Re: Minor Electrical Problem ??
take a good look at your earth's (copper slip works well).B)
  • Bannerbrother
15 years 6 months ago #16400 by Bannerbrother
Replied by Bannerbrother on topic Re: Minor Electrical Problem ??
Cheers. Where is the earth for the handbrake light then?
A good wack and the heater control lights appear to be working again so will have a look at the connection at the weekend.
  • Fzrandy
15 years 6 months ago #16414 by Fzrandy
Replied by Fzrandy on topic Re: Minor Electrical Problem ??
Hi there had exactly the same problem with my jimny ... brake warning light coming on ... After checking all over including bleeding brakes and disconnecting master cylinder plug.. turned out the problem was the ignition switch .. As you start engine the light comes on however i think the return spring in the barrel is weak and does not return the key to the correct position after starting i just turned key back slightly until slight resistance felt and light goes off and no further probs ... dont know how to fix this yet some WD40 seemed to help but might need to replace barrel ... Hope this helps ... Cheers Andy
15 years 6 months ago #16466 by Johnniehec
Ditto the heater control back lights, must be common, a slap to the dash above them fixes it for a while, I've not bothered investigating yet. Might look at the engine management light first, it's been on for about 18 months! for no aparent reason even the emissions were ok at MOT time!
John.
  • darthloachie
15 years 6 months ago #16476 by darthloachie
Replied by darthloachie on topic Re: Minor Electrical Problem ??
what!!!!! they're supposed to light up!!! :ohmy:
Time to create page: 0.096 seconds
