Spotlight relay wiring help
  • coptleigh
27 Apr 2011 17:16 #15565 by coptleigh
Spotlight relay wiring help was created by coptleigh
Fitted a pair of spots to the front today, now I'm sure I read somewhere that the high beam wiring is different to most other cars, negative switch or something,
If so what is the rearranged wiring to the relay?? so which number pins(86/87/ etc ) get which wire, ie power/ high beam circuit/ earth etc
Hope this makes sense??
Cheers
Alan
  • dirtydogz
27 Apr 2011 17:24 - 27 Apr 2011 17:24 #15566 by dirtydogz
Last edit: 27 Apr 2011 17:24 by dirtydogz.
  • coptleigh
27 Apr 2011 19:42 - 27 Apr 2011 19:43 #15573 by coptleigh
Replied by coptleigh on topic Re: Spotlight relay wiring help
Thanks for the pointer
Had a look at it, but have to admit, cannot make a great deal of sense from it, with my limited know how of electrics, all i need to know is, can I use the relay supplied with the lamps, and which wires do i need to connect and to where? swop wires to different numbers on the relay to cater for a switched earth?? or does it require more and different wiring??
Cheers
Alan
Last edit: 27 Apr 2011 19:43 by coptleigh.
  • ooky_123
27 Apr 2011 21:13 #15579 by ooky_123
Replied by ooky_123 on topic Re: Spotlight relay wiring help
with the jimny its easy ... a standard automotive relay SPST has 4 terminals ..
the terminals are usually numbered 30, 87, 85,86
30 and 87 are the low current "switch" circuits, and in a simple installation, would take a feed direct from the positive of the main beam (30) and then connect to earth (87) .. this will cause the relay to "click" when you put main beam on.
Now, in order to light the spot lights, you need to take a high current feed from the battery (ideally via a fuse) to the high current side of the relay (85). next, take a feed from (86) to your spotlights (+ve), and then earth the spotlights.
This will give you the spotlights comming on with main beam.
you can take it a step further by putting a switch in before the relay (30) to isolate the spotlights if you donot want to have them on when you put main beam on all the time.
check out 4 pin relays here
www.reuk.co.uk/Automotive-Relays.htm
  • coptleigh
27 Apr 2011 21:32 #15580 by coptleigh
Thanks for that, now I think I understand, I'll wire it up as you state tomorrow and sort it out, just out of curiosity, looking at the wiring diagram, I am assuming that the positive for the main beam is the red wire going to the holder on the headlamp bulb?
Cheers
Alan
  • coptleigh
27 Apr 2011 21:35 #15581 by coptleigh
ooky_123
Just noticed also, often down your neck of the woods, got family who live in Wildhern, nice part of the country you live in!!!
Alan
