Spotlight relay wiring help
  • mcjimny
27 Apr 2011 21:44 #15583 by mcjimny
Replied by mcjimny on topic Re: Spotlight relay wiring help
I'm so glad someone else couldn't make sense of it.
Thanks ooky for the laymans explaination!
To put in a switch before the relay i go from main beam to the switch then back to the relay?
I really don't do wiring. :blush:
28 Apr 2011 05:46 #15587 by mlines
ooky_123 wrote:
30 and 87 are the low current "switch" circuits, and in a simple installation, would take a feed direct from the positive of the main beam (30) and then connect to earth (87) .. this will cause the relay to "click" when you put main beam on.
This will not work on the Jimny as the original poster has already correctly spotted that the headlights on a Jimny are negatively switched. Therefore the positive feed to the lights is always on, connecting a relay in this way will mean is always on. You need to wire a permanent live to (30) on the relay and connect the earth of the relay (87) to the switched wire from the headlamp switch in the car.
Take a look at my diagrams here
www.bigjimny.com/images/Suzuki/Wiring/visio-wiring2.pdf
on the second page called "Jimny accessory wiring" you can see the spot-light relay (which I called "Main Beam Relay" in the centre of the diagram at the top. You can see it has a red "live" feed and the switching is on the earth (black) side and goes off to the headlamp switch on the steering column.
  • coptleigh
28 Apr 2011 11:36 - 28 Apr 2011 11:37 #15596 by coptleigh
Replied by coptleigh on topic Re: Spotlight relay wiring help
Martin,
Thanks for the info, would it be possible to give me more of a laymans guide to wiring the relay,
ie 30 to where
87 to where
85 " "
86 " "
Am I correct in thinking, that 30 is a fused permanent live
87 goes to the high beam circuit(to pick up being switched on)
if thats so what do I connect to the other two?? one is obviously the feed to the spots? which one?
Cheers
Alan
Last edit: 28 Apr 2011 11:37 by coptleigh.
  • renard38
28 Apr 2011 17:05 #15601 by renard38
Replied by renard38 on topic Re: Spotlight relay wiring help
hi,
i have do this on my jimny:
[img
A+
  • coptleigh
28 Apr 2011 17:11 #15602 by coptleigh
Would the image below do the trick, is this the way to wire up the relay to get the lights to work with the high beam circuit??
Cheers
Alan
Attachment neg2pos.gif not found
  • coptleigh
28 Apr 2011 17:14 #15603 by coptleigh
Well how about that for a coincidence,
Previous post showing exactly what I just found, Thanks Renard38, my french for colours is not good, but will look them up.
Cheers
Alan
Time to create page: 0.343 seconds
