Spotlight relay wiring help
28 Apr 2011 17:53 #15605
Replied by mlines on topic Re: Spotlight relay wiring help
Your diagram is correct Alan based on my understanding of relay numbering.
Renard has posted the same and shows the "Trigger" feed going to the headlamp via a switch on the dashboard.
The following user(s) said Thank You: coptleigh
- coptleigh
28 Apr 2011 18:06 #15607
by coptleigh
Replied by coptleigh on topic Re: Spotlight relay wiring help
POOH
Just had a go at wiring up the relay as shown, still not working, checked the wiring and only possible explanation is the link to the main beam circuit, I tapped into it near the bulb holder, is this OK. done it before and all OK on other cars, but am I using the right wire, from what I can see from the wiring diagram, I used the mainly solid red wire??? is this the one>> or one of the other two, or should I pick up the feed from somewhere else?
Alan
Alan
- coptleigh
29 Apr 2011 16:12 #15635
by coptleigh
Wired up and working fine , so thanks to all for help and advice.
Cheers
Alan
PS How does the steering wheel middle cover come off so I can check the horn buttons??
Cheers
Alan
- Back in Black
23 Dec 2011 14:13 #29055
by Back in Black
Replied by Back in Black on topic Re: Spotlight relay wiring help
Excellent diagram - spot lights wired up and working!!
Angel eyes (LED outer ring) wired to side lights, main spots wired to main beam
Thank you
Thank you
- dirtydogz
23 Dec 2011 16:48 #29076
by dirtydogz
Replied by dirtydogz on topic Re: Spotlight relay wiring help
I think renard38@coptleigh need a big thank you, for their drawings, it's so simple to work out.
I've just add one wire to the drawing to light up the switch
DIRTYDOGZ
Attachment neg2pos_2011-12-23.gif not found
Attachment DSCF1638_2011-12-23.JPG not found
DIRTYDOGZ
- Back in Black
24 Dec 2011 08:00 #29144
by Back in Black
Sorry, it was Renards drawing I followed. Until I found that I was in the dark (literally)
Now if only I could fix my reversing lights!!
