Spotlight relay wiring help
- Thank you received: 1999
19 Feb 2019 05:38 #203427
Replied by Lambert on topic Spotlight relay wiring help
Sounds like a latching relay not a switching one either that or it's defective internally?
19 Feb 2019 12:04 - 19 Feb 2019 12:06 #203452
by kirkynut
Replied by kirkynut on topic Spotlight relay wiring help
This is Dave Jones' diagram for the future reference of anyone who stumbles across this post:
On the back of the headlamp plug you need to pull the rubber insulation off of the plug its self and look at the back of the plug where the wires are crimped into place. You need the red wire with grey dots on it marked 'drive' on the plug. You'd think it would be the one marked 'pass' but it's not.
If they're staying on when you turn your main beam off I suggest that there is an issue with the relay sticking. They're cheap enough. Halfords sell Ring relays, which I have historically used and they seem reliable enough.
Last edit: 19 Feb 2019 12:06 by kirkynut.
22 Jul 2024 12:07 #256909
by Spitfire9
Replied by Spitfire9 on topic Spotlight relay wiring help
Does the high beam wire have 12v on dip and then when switched to high beam it goes away,does than mean it goes to earth,so it's eating the relay?
22 Jul 2024 12:33 #256910
by fordem
Replied by fordem on topic Spotlight relay wiring help
What does 'eating the relay" mean?
Yes, the high beam wire has 12v on it until you switch to high beam at which time it goes to ground/earth.
22 Jul 2024 12:44 #256911
by Spitfire9
My jb74 lcv has h4 lamps and the wire colour is yellow brown and black on offside front headlamp, which one to connect to main beam going to relay or if I have separate switch in cab does it go to that?
22 Jul 2024 23:48 #256923
by Filipao
Replied by Filipao on topic Spotlight relay wiring help
Brown
