Selective overheating...
- DVs-Jimny
19 Apr 2011 10:58 - 19 Apr 2011 10:59 #15233
by DVs-Jimny
Selective overheating... was created by DVs-Jimny
1999 Jimny 70K on the clock...
OK, when I bought this vehicle it overheated and went back to the garage. Apparently it had previously had a head gasket fitted but was bodged. The garage removed the head, sent it of to be re surfaced and then reassembled. They also fitted a new viscous fan, new stat and reverse flushed the block and rad. That then seemed to solve the problem.
Now this morning I took SWMBO to Tesco's (about an 8 mile journey), due to a Corsa sitting on my bumper I did raise the speed to about 75 and drove at this speed for a few minutes. It was then that I noticed the temp guage climbing. (It normally sits at half way). This was around a few minutes before we reached our destination. Whilst she was running hot she started to hold back (expected that really, and when we came to a stand still the revs dropped lots lower on tick over as normal to the point that the oil light was flickering).
Went and did our shopping (about an hour or so). Returned to the vehicle, stuck the heater to hot and drove home keeping the speed to under 55. No overheating or probs. Temp guage climbed to half way and stayed there...
I'm starting to think the rad is blocked. Now before I shell out £100 for a new one I thought I'd ask your opinions. I just HATE having an unreliable motor
Thanks in advance.
Thanks in advance.
Last edit: 19 Apr 2011 10:59 by DVs-Jimny.
- viciouspenguin
19 Apr 2011 11:03 #15235
by viciouspenguin
Replied by viciouspenguin on topic Re: Selective overheating...
might be worth taking it out and giving it a clean yourself. i did that with mine as it heated up a bit too quicly for my liking. Also check the fins are not all bent over etc.
- DVs-Jimny
19 Apr 2011 11:12 #15237
by DVs-Jimny
Replied by DVs-Jimny on topic Re: Selective overheating...
Cheers for that, I'll have a looksie.
- downhilldude
19 Apr 2011 21:30 #15262
by downhilldude
Replied by downhilldude on topic Re: Selective overheating...
Thermostat? Our Landcruiser did this, drove fine no probs, but when we had it loaded with a 2tonne trailer and pulling up a hill the temp gauge started to rise.Might be worth looking into.
Easy to test yourself anyway.
- ooky_123
20 Apr 2011 06:39 #15265
by ooky_123
Replied by ooky_123 on topic Re: Selective overheating...
Second vote for the Rad .. when driving in low though sticky mud, ours overheats. The source of teh problem ... Rad full of silt and mud, plus lots of bent fins.
New rad has been sat in teh garage for the last 6 months waiting to be fitted... Summer Job I think !
- DVs-Jimny
20 Apr 2011 07:54 #15267
by DVs-Jimny
Cheers guys, it's had two stats so I'm pretty sure it's not that. Will drain and pull out the rad, I have a feeling that the previous owner has used magic sealer in the past when the HG was bodged
