Selective overheating...
  • bluejimny
20 Apr 2011 15:22 #15280 by bluejimny
Replied by bluejimny on topic Re: Selective overheating...
yeah sounds like the rad, you never no if they have used something like that K seal you can get
21 Apr 2011 06:04 #15293 by facade
Replied by facade on topic Re: Selective overheating...
Check the bottom hose. I noticed that mine has a kink flat in the middle, may be slightly too long. Never given me any trouble (yet) but it must restrict the flow.
I can't do anything about it with the water in.
  • DVs-Jimny
21 Apr 2011 10:41 #15307 by DVs-Jimny
Replied by DVs-Jimny on topic Re: Selective overheating...
Have drained the rad and noted what looks like copper particles, K seal?? Dumped a bottle of rad flush in and topped up with water. Stayed at normal temp (bonnet down), held revs at 2K and temp started to rise :(
Waiting for it to cool drain so I can drain it again and have a look at the water. Can hear gurgling sounds within the top hose. No mayonaisse under filler cap or on the dip stick.
Royal pain in the bum :huh:
Some fins are bent over on the rad but seeing as its getting too hot without driving I doubt now that that is the cause.
What do we reckon?
Thanks in advance
  • viciouspenguin
21 Apr 2011 10:49 - 21 Apr 2011 10:51 #15308 by viciouspenguin
Replied by viciouspenguin on topic Re: Selective overheating...
this might be an abvious question but does the fan go round. if it heats up when its just sitting generaly means theres no airflow over the radiator. if the rad is hot then there is water curculation.
if the radiator is not full of water then that could and will effect the cooling too.
let it cool down open the rad and fill it with water. run it without the lid off and keep topping it up for a minute or so.
Last edit: 21 Apr 2011 10:51 by viciouspenguin.
21 Apr 2011 10:50 #15309 by facade
Most likely the radiator is blocked inside and restricting water flow. I doubt if radflush will shift a blockage.
It will overheat standing if you rev it, it is not a Landrover, which is supposed to run whilst stationary.
Is the fan driving? it should be blowing a gale if the engine is overheating. When stationary, the viscous unit should show some resistance to turning the fan blades by hand.
  • DVs-Jimny
21 Apr 2011 11:04 - 21 Apr 2011 11:06 #15310 by DVs-Jimny
Fan appears ok and it is definitely a new viscous unit. Will drag the rad out and reverse flush it. Cheers guys
From an empty rad to full it's taking slightly more than 2.5 litres if that helps
Last edit: 21 Apr 2011 11:06 by DVs-Jimny.
