Jimny diff protection
jtayl153 wrote: Heres mine - attached. 5 mins to put on or remove.
I don't have it on day to day but it's taken a bit of a beating lately.
Attach before going to the pub, remove when you need to go off-road?
It's no surprise it's taken a beating. It must catch on every rock, stump, stick, leaf and cigarette end you drive over!
- Bits4Vits
- Visitor
Busta wrote: I can't work out how that strip of metal is supposed to strengthen or protect anything?
It's not my design, but I figure it's a 6mm arc of steel plate that's welded onto the front pan of the diff to protect the crown wheel from getting knocked by rocks denting the original (thinner by comparison) axle casing...?
- Bits4Vits
- Visitor
Busta wrote: It's bolted between the radius arm brackets which are welded to the axle housing and don't move relative to each other. The radius arms can still flex on their bushes as usual.
Nah, under articulation one radius arm goes up and one goes down, but it would be hampered by an arm-to-arm guard, even if the bushes can still twist... the arms are effectively bolted together...?
- TomDK
- Visitor
Just how are the arms affected by this guard?
It bolts directly to the inner side of the radius arms mounts. So the arms and bushes are in no way affected by the guard.
So no, the arms are not bolted together.
- bluejimny
- Visitor
This is correct this guard will have no effect on the arms
- Bits4Vits
- Visitor
Think of one arm going up, and the other arm going down... now think about bolting something in between them, and again imagine their movement under articulation... one up, one down...
