Jimny diff protection
  • Bits4Vits
  • Visitor
  • Visitor
10 Jul 2014 08:39 #119652 by Bits4Vits
Replied by Bits4Vits on topic Jimny diff protection
Surely straight-across between-the-radius-arms guards such as that would be detrimental to suspension flex too?
Don't the arms need to move independently? :unsure:
  • Bits4Vits
  • Visitor
  • Visitor
10 Jul 2014 09:15 - 10 Jul 2014 09:18 #119659 by Bits4Vits
I'll weld one to the front of mine when the diff is out for the LSD and matching 26 spline shafts and HD CVs going in...
I'll weld a plate under the diff too, to protect that bit too...
Mine will see rocks! (I don't drink and drive, so I'll walk to the pub and leave it at home ;) )
Last edit: 10 Jul 2014 09:18 by Bits4Vits.
  • jtayl153
  • Visitor
  • Visitor
10 Jul 2014 09:47 #119661 by jtayl153
Replied by jtayl153 on topic Jimny diff protection
Heres mine - attached. 5 mins to put on or remove.
I don't have it on day to day but it's taken a bit of a beating lately.
  • TomDK
  • Visitor
  • Visitor
10 Jul 2014 10:45 - 10 Jul 2014 11:15 #119665 by TomDK
Replied by TomDK on topic Jimny diff protection
jtayl153 wrote: Heres mine - attached. 5 mins to put on or remove.
with one of those, you're sure to catch every little rock and bump.
Last edit: 10 Jul 2014 11:15 by TomDK.
10 Jul 2014 11:11 #119666 by Busta
Replied by Busta on topic Jimny diff protection
Bits4Vits wrote: I'll weld one to the front of mine when the diff is out for the LSD and matching 26 spline shafts and HD CVs going in...
I can't work out how that strip of metal is supposed to strengthen or protect anything?
10 Jul 2014 11:13 #119667 by Busta
Bits4Vits wrote: Surely straight-across between-the-radius-arms guards such as that would be detrimental to suspension flex too?
It's bolted between the radius arm brackets which are welded to the axle housing and don't move relative to each other. The radius arms can still flex on their bushes as usual.
10 Jul 2014 11:17 #119668 by Busta
Attach before going to the pub, remove when you need to go off-road?
It's no surprise it's taken a beating. It must catch on every rock, stump, stick, leaf and cigarette end you drive over!
  • Bits4Vits
  • Visitor
  • Visitor
10 Jul 2014 12:21 - 10 Jul 2014 12:23 #119672 by Bits4Vits
Busta wrote: I can't work out how that strip of metal is supposed to strengthen or protect anything?
It's not my design, but I figure it's a 6mm arc of steel plate that's welded onto the front pan of the diff to protect the crown wheel from getting knocked by rocks denting the original (thinner by comparison) axle casing...?
Last edit: 10 Jul 2014 12:23 by Bits4Vits. Reason: spooling mistack
  • Bits4Vits
  • Visitor
  • Visitor
10 Jul 2014 12:29 #119673 by Bits4Vits
Busta wrote: It's bolted between the radius arm brackets which are welded to the axle housing and don't move relative to each other. The radius arms can still flex on their bushes as usual.
Nah, under articulation one radius arm goes up and one goes down, but it would be hampered by an arm-to-arm guard, even if the bushes can still twist... the arms are effectively bolted together...?
  • TomDK
  • Visitor
  • Visitor
10 Jul 2014 13:12 - 10 Jul 2014 13:13 #119674 by TomDK
Just how are the arms affected by this guard?
It bolts directly to the inner side of the radius arms mounts. So the arms and bushes are in no way affected by the guard.
So no, the arms are not bolted together.
Last edit: 10 Jul 2014 13:13 by TomDK.
  • bluejimny
  • Visitor
  • Visitor
10 Jul 2014 13:18 #119676 by bluejimny
Replied by bluejimny on topic Jimny diff protection
This is correct this guard will have no effect on the arms
  • Bits4Vits
  • Visitor
  • Visitor
10 Jul 2014 13:21 #119678 by Bits4Vits
The radius arms need to deflect side to side, "twist" under articulation, with something rigid bolted between them this is obviously hampered...?
Think of one arm going up, and the other arm going down... now think about bolting something in between them, and again imagine their movement under articulation... one up, one down...
Time to create page: 0.235 seconds
