Lambda/O2 Sensor Harness location
- markyp2000
03 Oct 2013 14:16 #85078
by markyp2000
Replied by markyp2000 on topic Lambda/O2 Sensor Harness location
Has it got a body lift
- X-Eng Simon
03 Oct 2013 14:26 #85080
by X-Eng Simon
It has - but it was done by the previous owner.
Si
Replied by X-Eng Simon on topic Lambda/O2 Sensor Harness location
markyp2000 wrote: Has it got a body lift
Si
- markyp2000
03 Oct 2013 16:46 #85084
by markyp2000
Could you get a pic so we know if we are talking about the same plug
- X-Eng Simon
04 Oct 2013 09:34 #85155
by X-Eng Simon
- X-Eng Simon
04 Oct 2013 10:04 #85158
by X-Eng Simon
- X-Eng Simon
04 Oct 2013 12:06 #85166
by X-Eng Simon
Found It!
I traced the wired from the ECU by stripping the insulation off the loom at each Junction. It eventually comes out the same cable as connects to the Alternator & Starter. There is a third branch at the same place they separate which goes to the reverse light switch and the Lambda Sensor connector. However, it comes out on the wrong side of the engine - and the leads are 30cm too short! What gives?
It appears it connects to the gearbox loom. The reverse light, obviously connects to the gearbox. The Lambda goes in to the gearbox loom - then pops out above the bell housing where the sensor can plug in.
When I swapped from Manual to Auto - and removed the gearbox loom - it must have been forgotten! When I found the original loom - the appropriate connectors were there. I just stripped out this interconnect and installed it as an extension.
Si
Si
Time to create page: 0.150 seconds
