Lambda/O2 Sensor Harness location
  • X-Eng Simon
13 Oct 2013 18:16 #86077 by X-Eng Simon
Replied by X-Eng Simon on topic Lambda/O2 Sensor Harness location
Why?
I don't know specifically about the Jimny ECU, but on Land Rovers, it's a P Channel FET with the source connected to +12v, Drain connected to the output and a flyback diode between the output & 0v (with a 10k resistor in parallel with the diode) - thus feeding 12v into the output does nothing!
Granted, on some outputs, mainly driving capacitive rather than inductive loads, a second N channel FET is added to pull the output down to ground - and in that case you would be correct. I doubt they would add the second FET unless it was necessary though.
The other option is when it uses a switched earth - where you would have an N channel FET between the output & ground, but this output is switched live.
It may be that Suzuki ECU's work differently - so I bow to your greater knowledge if that is the case.
Si
Time to create page: 0.074 seconds
