Lambda/O2 Sensor Harness location
- X-Eng Simon
03 Oct 2013 11:04 #85057
by X-Eng Simon
Lambda/O2 Sensor Harness location was created by X-Eng Simon
I've just replaced my Auto Box and in the process discovered that the Lambda Sensor connector has melted - and there is no sign of where it connected to in the wiring harness! It's possible the wires have been pulled out of the loom!
It explains why the engine was running so badly! Do any of you know where or which bit of the loom the Lambda sensor originally connected to / which bit it branches out from so I know where to start stripping the insulation?
It's a 1999 Spanish Built Jimny with a G series Engine.
Thanks in advance,
Si
Thanks in advance,
Si
- Dave cc
03 Oct 2013 11:22 #85061
by Dave cc
Replied by Dave cc on topic Lambda/O2 Sensor Harness location
My Jap built Jimny Sensor connection came from the main ECU harness that ran the injectors and the other engine sensors all come off of the one harness on my truck
- X-Eng Simon
03 Oct 2013 11:44 #85068
by X-Eng Simon
Replied by X-Eng Simon on topic Lambda/O2 Sensor Harness location
Thanks Dave.
There is a 6 pin connector on the main loom that was obviously connected to something - but nothing obvious. Is it possible there was something which connected to that with a tail connecting to the Lambda - which has since been lost?
There has been a 6 month gap between removing the engine & putting it back in (no time) and I can't remember enough of the details!
Si
Si
- Dave cc
03 Oct 2013 11:47 #85069
by Dave cc
Think it was a green 2 pin plug if I remember correctly will have a look to nite when I get in my loom is just clipped up on the bulk head since I went Diesel so will be able to see it easily
- markyp2000
03 Oct 2013 12:30 #85072
by markyp2000
Replied by markyp2000 on topic Lambda/O2 Sensor Harness location
Mine was cliped the the rear of the head just above the gearbox
- X-Eng Simon
03 Oct 2013 13:16 #85075
by X-Eng Simon
Mine has a green 4 pin connector, clipped on to the rear of the head with about 70mm between the clip & connector. There is just nothing else on the loom that I can find long enough to go anywhere near it! Hence wondering if it's been ripped out of the main loom.
Si
Si
Time to create page: 0.123 seconds
