Lambda/O2 Sensor Harness location
- markyp2000
04 Oct 2013 18:02 #85184
by markyp2000
Replied by markyp2000 on topic Lambda/O2 Sensor Harness location
Well done we was in the right area around the gear box hows it running now
- X-Eng Simon
04 Oct 2013 19:13 - 04 Oct 2013 19:16 #85194
by X-Eng Simon
Not quite running yet! Still loads of stuff to connect, but hope to have it started tomorrow some time. It won't be driving for a week or two as I'm waiting for AliSport to make me a new Radiator which is about half the size of the original.
I've fitted an Auto Box out of a late vitara, which turned out to be 76mm longer than the box I had before - so everything has had to move around a bit to fit.
The box is going to be controlled by this:
Replied by X-Eng Simon on topic Lambda/O2 Sensor Harness location
markyp2000 wrote: Well done we was in the right area around the gear box hows it running now
Last edit: 04 Oct 2013 19:16 by X-Eng Simon.
05 Oct 2013 16:58 #85250
by jimkyx
Replied by jimkyx on topic Lambda/O2 Sensor Harness location
Love all this talk about Automatic Gearboxes. Can not wait to see the update on the Auto Controller. Only ever seen these things before on American Custom Car programs.
- X-Eng Simon
05 Oct 2013 17:04 #85251
by X-Eng Simon
Is there another kind of gearbox?
Nothing beats Auto off road, apart perhaps from one which you can control yourself in Software!
My Jimny started and ran today for the first time with the new gearbox - which is good! I just need to wait for AliSport to make me a custom Rad and I'll be able to play with the gear controller in earnest. I drove it about 50 feet today without any cooling system - just to make sure it worked.
Si
Si
11 Oct 2013 14:59 #85827
by jimkyx
This level of sophistication on a road Jimny would probably not get the use it deserves. However, to be able to control the lock up for say 3rd and 4th would be great. Any ideas.
- X-Eng Simon
11 Oct 2013 15:04 #85829
by X-Eng Simon
If your box is electronically controlled, the TC Lockup is just controlled by a solenoid valve - which you could power with a push button! Just splice in to the TCC wire and connect to +12v via a switch or push button. Then, the gear controller will control it as normal, but when you power it via the switch, it will lock up for you on demand.
Si
Si
Time to create page: 0.162 seconds
