Turbo M16A Jimny
10 Jun 2022 05:27 #243656 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
UPDATE
The wastegate on the turbo is allowing to much boost. It should be half a bar (.5) but boosting up to .8. I contacted the Turbozentrum where I ordered it and they sent another actuator but its weirdly doing the same thing. Turbozentrum are now looking into it. On a positive note, the tuner was surprised how much power the engine was producing at .5 before it creeps up. He says its 150 ft-lb (81 ft-Ib is standard jimny) He is going to tune the vehicle for the most low down torque possible.
23 Jun 2022 06:33 - 23 Jun 2022 19:59 #243792 by Motleycrew
good news that the "boost creep" has been put under control. The turbo is slightly undersized so the exhaust gasses from the engine quickly spool up the small turbine and then the compressor then produces its .5 bar for the intake. The problem then is there is so much exhaust gas left over that it doesnt have time to escape down the exhaust port on the wastegate and then carries on spooling the turbine, producing more boost. The solution for this was porting the exhaust port. This video explains it clearly:
(23) Internal Wastegate Porting (Broke & Boosted Ep4.1) - YouTube
Last edit: 23 Jun 2022 19:59 by Motleycrew.
23 Jun 2022 06:37 #243793 by Motleycrew
This is the turbo that may of eliminated that boost creep. Its the next size up from my one.
Garrett Boost | Club Line GBC20-300 (garrettmotion.com)
25 Jun 2022 12:29 #243816 by Motleycrew
153BHP and 147 ft/lb of torque
25 Jun 2022 12:30 #243817 by Motleycrew
It’s quick but completely controllable. I honestly reckon it should have that as standard.
25 Jun 2022 13:14 #243818 by Motleycrew
This is a very safe tune. The rev limiter is set at 6000RPM. You could probably push it more but I will quit while I am ahead. Might put forged rods in the future, but time to enjoy it now.
Time to create page: 0.327 seconds
