Turbo M16A Jimny
- Motleycrew
Topic Author
- Elite Member
- Thank you received: 23
01 Jul 2022 21:01 #243925
by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
When the engines exhaust gasses hit the turbine in the turbo, it baffles the sound, I am hoping I can lose the whole muffler as it will increase the flow and make it sound sportier. It’s so silent now it’s sereal! I keep thinking it’s stalled at idle
- Motleycrew
Topic Author
- Elite Member
10 Jul 2022 15:40 #244033
by Motleycrew
Fitted a spoiler that was well made (or copied) but the fixing system supplied didn’t work so it has been bonded with tiger seal and there are two holes in the rear door that I drilled and there are two bolts on the spoiler that are loosely inserted. Should hold as it’s purely cosmetic. I also put the CAN gauge on and routed the cables. Will wire it when it’s not 30 degrees.
- Motleycrew
Topic Author
- Elite Member
10 Jul 2022 19:02 #244036
by Motleycrew
need to replace the steering wheel. The rubber has come loose from the metal. The jimny steering is vague enough let alone when the actual wheel moves! was looking a few options:
-replace original for same generation (looks most sensible)
-put one on from a swift sport (not sure if it will fit)
-put quick release and delete airbag (never a good idea to remove life saving devices)
any ideas?
any ideas?
- Motleycrew
Topic Author
- Elite Member
10 Jul 2022 19:10 #244037
by Motleycrew
I have already decided I am going to forge the engine. The Jimny is rapid with 150BHP but I want to make it more ridiculous. Before I took it to the Dyno I changed the suspension damping to the hardest setting. It has transformed it at speed and feels planted. I believe I will only need to put forged rods in and bearings for them.
this company specialises in Suzuki is awesome and the owner is super helpful. They have these rods:
K1 Connection Con Rod Set For Suzuki Swift Sport ( 2005 Onwards) - CTC Performance Car Parts (ctc-performance.co.uk)
- redoregan
05 Aug 2022 21:11 #244408
by redoregan
Replied by redoregan on topic Turbo M16A Jimny
Well, this is about the coolest thing ever. Thanks for sharing, mate!
- Motleycrew
Topic Author
- Elite Member
23 Feb 2023 21:27 #247724
by Motleycrew
exhaust system finally finished
Time to create page: 0.192 seconds
