28 Mar 2016 16:30 #164532 by mlines
That's interesting, I had a rival kit and the pads wore down cheese shaped (wedge shape) within a couple of events, so at least the wear is even across the pad itself. You should see the rear pads and discs from my Range Rover after launching the boat in salt water! :eek: :eek: :eek:
Let me know how it goes, parts shipped special delivery tomorrow
Sent from my Nexus 6P using Tapatalk
The topic has been locked.
  • OllieNZ
28 Mar 2016 18:13 #164537 by OllieNZ
Replied by OllieNZ on topic Dave's "S200KYS" Jimny 'laner Build...
Uneven pad wear could be a combination of the brake piston not retracting fully and/or the caliper not floating correctly.
  • S200KYS
28 Mar 2016 18:35 #164538 by S200KYS
Replied by S200KYS on topic Re:Dave's "S200KYS" Jimny 'laner Build...
mlines wrote: That's interesting, I had a rival kit and the pads wore down cheese shaped (wedge shape) within a couple of events, so at least the wear is even across the pad itself. You should see the rear pads and discs from my Range Rover after launching the boat in salt water! :eek: :eek: :eek:
Thanks Martin ;) Impecable service as always! B)
Hopefully with the shim behind the disk, and I'll jack it up to full droop and see if the brake goes on if the handbrake cable does go taut, and a new set of pads on (windey brake tool already ordered)... Should be ok for another dozen trips or so... I can live with a set of cheap pads from time to time... another consumable part :whistle:
  • S200KYS
28 Mar 2016 18:40 #164539 by S200KYS
OllieNZ wrote: Uneven pad wear could be a combination of the brake piston not retracting fully and/or the caliper not floating correctly.
Thanks Ollie...
The calipers were new in June with the kit, they come as an option - www.jimnybits.co.uk/shop/jimny/brakes/ji...n-kit/prod_1405.html - rather than using calipers from a breaker / salvage yard, so they should be alright? :unsure:
  • wombat
28 Mar 2016 19:00 #164540 by wombat
Replied by wombat on topic Dave's "S200KYS" Jimny 'laner Build...
You could swap the pads over after every couple of trips out so they wear evenly :)
  • OllieNZ
28 Mar 2016 19:04 #164541 by OllieNZ
Replied by OllieNZ on topic Re:Dave's "S200KYS" Jimny 'laner Build...
It could be a flaw in the mounting that's preventing them floating. It's an issue we suffer a lot on the aircraft at work. Could be something simple like copperslip plus brake dust and heat = solid mass or something a bit more subtle like a brake line pulling the caliper in one direction or another. It doesn't take much external pressure to twist on the caliper to cause the pins to bind and stop it floating. Maybe worth another look at the installation if it still uses the stock park brake cables they could be causing the issue especially during articulation
Time to create page: 0.275 seconds
