04 Apr 2016 18:34 #164864
Replied by jackonlyjack on topic Dave's "S200KYS" Jimny 'laner Build...
maybe time to sort out the vac hubs and fit a 2 low switch
Jack
Jack
The topic has been locked.
- S200KYS
04 Apr 2016 19:28 #164871
by S200KYS
Thanks Dan
Good idea Jack!
They are sat on a shelf in the garage pending sorting them out an refitting :laugh:
Daniel30 wrote: fingers crossed for you Dave that's very unfortunate :blink:
Thanks Dan
jackonlyjack wrote: maybe time to sort out the vac hubs and fit a 2 low switch
Jack
Good idea Jack!
- GraphicX
05 Apr 2016 02:47 #164879
by GraphicX
Replied by GraphicX on topic Dave's "S200KYS" Jimny 'laner Build...
wouldn't it be easier & more reliable to fit manual hubs over the vacuum jobs (is that what you're talking about) ??
05 Apr 2016 13:39 #164901
Replied by Daniel30 on topic Dave's "S200KYS" Jimny 'laner Build...
Just asking the question :blush: but why would you want 2wd Low? Why would you not just use 4wd low?
- Paul_sterling
05 Apr 2016 14:43 #164904
by Paul_sterling
usually for areas where you require low speed (so perhaps somewhere with tight turns or steep gradients) but have good grip (and so if using 4 Low you would wind up the transmission).
I used to use 2L on the second vitara in traffic jams, as it had manual locking hubs, so I could crawl along saving the clutch without winding the transmission up.
Paul.
Replied by Paul_sterling on topic Dave's "S200KYS" Jimny 'laner Build...
Daniel30 wrote: Just asking the question :blush: but why would you want 2wd Low? Why would you not just use 4wd low?
Paul.
05 Apr 2016 14:55 - 05 Apr 2016 14:56 #164905
by Halford
Replied by Halford on topic Dave's "S200KYS" Jimny 'laner Build...
Busta made a guide
here
a little while back :ohmy:
but its not for the VVT, the wiring is different on the newer electric switch AWD selection.
will need to find the 4wd connector on the transfer box and see what colour wires go into it. Or look at all the vacuum hub control stuff near the battery and see if any of the wires near the handbrake match the wires there.
I fancied it for traffic jams - or should that be Jim-Jams :dry:
Last edit: 05 Apr 2016 14:56 by Halford.
Time to create page: 0.295 seconds
