  • S200KYS
28 Mar 2016 19:19 #164542 by S200KYS
Replied by S200KYS on topic Re:Dave's "S200KYS" Jimny 'laner Build...
OllieNZ wrote: It could be a flaw in the mounting that's preventing them floating. It's an issue we suffer a lot on the aircraft at work. Could be something simple like copperslip plus brake dust and heat = solid mass or something a bit more subtle like a brake line pulling the caliper in one direction or another. It doesn't take much external pressure to twist on the caliper to cause the pins to bind and stop it floating. Maybe worth another look at the installation if it still uses the stock park brake cables they could be causing the issue especially during articulation
Hmmm... will have a good stare at it all when it's back together, thanks Ollie! B)
The topic has been locked.
  • S200KYS
28 Mar 2016 19:21 #164543 by S200KYS
wombat wrote: You could swap the pads over after every couple of trips out so they wear evenly :)
Hopefully the shims should stop it Wombat, but I'll keep an eye on the pads and swap them / report back over time... ;)
  • OllieNZ
28 Mar 2016 19:23 #164544 by OllieNZ
Replied by OllieNZ on topic Re:Dave's "S200KYS" Jimny 'laner Build...
I should add if they do bind on the pins it can take manually squaring them up again to get them to unbind.
  • GraphicX
30 Mar 2016 03:35 #164624 by GraphicX
Replied by GraphicX on topic Dave's "S200KYS" Jimny 'laner Build...
were your sliders seized (possibly open) ? did you have rubber grease on them ?
30 Mar 2016 10:45 #164636 by maverick
GraphicX wrote: were your sliders seized (possibly open) ? did you have rubber grease on them ?
The thing is, in our little Jimny group, about 3-4 of us have the same set-up and we're all experiencing the same problem. To that end, JiumnyBits is on the case, and we're working on a solution - watch this space.
Jalapeño, IISY?
  • S200KYS
31 Mar 2016 10:48 #164691 by S200KYS
Shims arrived B)
Same shape as the end of the driveshafts -
Ta'Da! -
That should sort it? B)
Time to create page: 0.274 seconds
