- Thank you received: 1854
18 Aug 2018 16:44 #195224
Chicks dig scars! Apparently.
The topic has been locked.
- Thank you received: 923
25 Aug 2018 06:36 - 25 Aug 2018 06:36 #195419
Replied by X8GGY on topic Dave's "S200KYS" Jimny 'laner Build...
Up-to-date Spec'
'54 plate soft-top Jimny, hiding under the "S200KYS" personal plate
Suzuki rear hardtop section (front soft-top section retained for the odd nice day we get!)
JimnyBits +4" Diesel front springs on the rear, Mercedes C180 Saloon Springs on the front ~5" lift
AVO adjustable +4" shock absorbers on the front, Trailmaster Combat shock absorbers on the rear.
Rockwatt Stainless Steel Adjustable Panhards
Zanfi +80mm rear panhard bracket
Rockwatt's Front and Rear Bump Stop spacers and poly bump stop cones
JimnyBits anti-rollbar disconnect system
Rockwatt Heavy Duty steering bars
Terrafirm Steering Damper on ZookBOB brackets
Rockwatt installed rear ARB Airlocker
Front diff currently 'open' as LSD is currently out, 26 spline converted
Front and Rear TrailGear HD Shafts (front 26 spline)
Rockwatt 4.87:1 Transfer Box (with two wheel drive low) and SPINED Bucket mount, with-
Speedo-ring to correct speedo for the-
Maxxis Trepador 31" x 10.5" tyres on JimnyBits 15" ET-30 offset Black Steel Modulars
Land Rover Defender +50mm wheel arches
Tyrex Free Wheel Hubs
JimnyBits (ABS) Battery Tray with Odyssey PC1200 winch battery fed by T-Max split charge system
ORA front winch bumper with Warrior 8,000lb "High Speed" Winch, Dyneema rope, dashboard and remote control
ORA rear bumper modified to fit round -
Rear Towbar adapted to take T-Max 9,500lb rear winch, Dyneema rope, dashboard and remote control
ORA 'flat-pack' roll hoop
ORA CAD-bent soft-top and rear fibreglass hard-top roof protection bars with -
Waffle Boards mounted on top (partly to protect the hard-top too)
My trusty old Cobra waterproof bucket seat
ARB compressor (for Airlocker) and tyre inflation line
JimnyBits rear disk brake (Renault Megane Calipes) conversion
ORA sill bars
JimnyBits front shock guards
ORA radius arm guards
JimnyBits fuel tank guard
(Genuine) Safari Snorkel adapted to sit inside bodyline with guard
BigJimny Breather Kit slightly modified to fit gearbox, transfer box and axles
Dash and handheld CBs
iPad with RAM mount running MemoryMap and TomTom SatNav (with Homer Simpsons voice!)
Front, Rear and inside work LED lights, all controlled from dash switch console
Hi-Lift Jack mounted across internal roll hoop
Ground Anchor behind driver's bucket seat
Zanfi bonnet net (for holding tree strop, etc)
Strops, Shackles, Bridles, Ropes behind passenger seat
Saw, Axe, Bolt Cutters, Rigid Tow Pole behind spare wheel mounted on rollhoop stays
Tools and Spares in two tote boxes behind the spare
Cordless Bosch 36v Chainsaw
Cordless Angle Grinder
First Aid Kit and Fire Extinguisher
ORA sill bars
Last edit: 25 Aug 2018 06:36 by X8GGY.
26 Aug 2018 05:48 #195426
That's cool.
28 Aug 2018 06:18 #195479
Unfortunately, the Bits4Vits domain expired recently, and I won't be renewing it - all the remaining stock is on eBay (link below) so the website and email have expired... that also means that a lot of my historic photos in this - and other - threads have disappeared. :S
Recently though I've been using photos from the greenlaning.blog and hosted here on the BigJimny board, so recent posts will appear alright.
The end of an era
I'm still selling products both as Bits4Vits and ZookBOB on eBay though... links in my signature below
The end of an era
29 Aug 2018 06:19 #195515
The next chapter awaits!
08 Sep 2018 06:00 #195782
Off to Northumnerland for the weekend...
Not a place we've greenlaned before so all the 'lanes will be new to us, rather than going "over old ground"...
Riccy has planned and checked all the routes though, so although they're all new, they're all passable and legal!
Blog soon
Blog soon
Time to create page: 0.806 seconds
