- Thank you received: 923
theoldseacaptain wrote: Recently bought the same calipers - they came out of the box with no lubricant at all on the slider pins, so may be worth checking yours if you haven’t already greased them up!
Yes, noticed that "theoldseacaptain"
Thanks!
maverick wrote: I've always considered getting a PRESS for home usage ... If you find a decent one that's suitable for our Rear Shafts and Front Hubs, let me know (maybe they can reduce cost for TWO???)
Normally, Mr. A. Grinder comes out to grind off the ABS Collar and Bearing, but only today I have found a local Community project called Shedheads. They have my two duff Rear Shafts with worn out bearings and decent ABS Collars "pressed" on. I asked them if they can heat up the AB collar and tap it off (then its re-useable) and maybe het up duff bearing and get that off too??? Then it'll be a trip to my friendly garage (they have a press) to pay them £10 a shaft to press bearing and ABS collar back on??? But IF i had a press, that would save me about £50 a year ...
From memory when we last discussed this, Martin has something like this -
www.machinemart.co.uk/p/clarke-csa10ep-1...nomy-hydraulic-floo/
So we'd dangle the rear shaft through the hole and then press the shaft down onto the bearing / ABS Collar ?
My local garage do it with a length of roll cage tube they pinched from me...! The tube goes over the shaft and the collar gets beaten home with a BFH (Big F... Hammer!)
I'll ask Santa for a press this year
- Thank you received: 115
And also testing the Autool OBD2 reader
- Thank you received: 1843
