- S200KYS
20 May 2018 17:21 #192828
by S200KYS
Thanks Dan’
Yes, quite chuffed, never done my own brakes before, always had the local garage do them, but figured I’d save on the labour, so rebuilt the cslipers and bled the brakes on my own... some silicon hose and an empty pop bottle!
Now sat in the garden with a magnum of Prosecco and the log burner on and some nibbles for starters...
The topic has been locked.
- Thank you received: 1988
21 May 2018 04:19 #192833
Good man, it's always satisfying to develop a new skill!
21 May 2018 09:42 #192837
by kirkynut
Replied by kirkynut on topic Dave's "S200KYS" Jimny 'laner Build...
I'm glad you've done your own brakes Dave. There's not a lot to it and you can see any leaks.
Bleeding isn't tricky. The only thing I haven't done yet is making up my own brake pipes but I ought to sort that out!
- S200KYS
21 May 2018 09:57 #192838
by S200KYS
Thanks Lambert
And Kirkynut
Yes, chuffed and saved some money too!
Bearing press next methinks?
And Kirkynut
- Thank you received: 115
21 May 2018 10:25 #192839
by maverick
Jalapeño, IISY?
Replied by maverick on topic Dave's "S200KYS" Jimny 'laner Build...
I've always considered getting a PRESS for home usage ... If you find a decent one that's suitable for our Rear Shafts and Front Hubs, let me know (maybe they can reduce cost for TWO???)
Normally, Mr. A. Grinder comes out to grind off the ABS Collar and Bearing, but only today I have found a local Community project called Shedheads. They have my two duff Rear Shafts with worn out bearings and decent ABS Collars "pressed" on. I asked them if they can heat up the AB collar and tap it off (then its re-useable) and maybe het up duff bearing and get that off too??? Then it'll be a trip to my friendly garage (they have a press) to pay them £10 a shaft to press bearing and ABS collar back on??? But IF i had a press, that would save me about £50 a year ...
Jalapeño, IISY?
- theoldseacaptain
- Junior Member
- Thank you received: 7
21 May 2018 13:03 #192840
by theoldseacaptain
Sadly jimny-less but still got the bug!
Replied by theoldseacaptain on topic Dave's "S200KYS" Jimny 'laner Build...
Recently bought the same calipers - they came out of the box with no lubricant at all on the slider pins, so may be worth checking yours if you haven’t already greased them up!
Time to create page: 0.290 seconds
