Step by step Isuzu diesel conversion
  • Dave cc
13 years 8 months ago - 13 years 8 months ago #64245 by Dave cc
Step by step Isuzu diesel conversion was created by Dave cc
Have started to get engine ready to go into Blue Jim so thought would start a step by step guide into what you need to do in case any others fancy going the same route
Engine out take all the ancillaries header tank starter motor and altenator and as may hoses as you can grab if early type altenator you will also need charge relay located in the drivers side kick panel forget the glow plug relay as its a arse to get to and a sod to get working a Pug 106 unit you can get for a tenner and are far easier to wire in also forget the astra radiator as well you will need a 300tdi discovery unit
Remove tin manifold covers
Turning the turbo housing to point north
Unbolt manifold and all the rest of the pipes remove manifold unbolt actuator and housing if garret turbo you can simply turn housing to point north and put bolts back in if IHI then you can only get 2 of the 5 bolts in the others wont line up so you will need to drill and tap 3 holes M5 and idealy replace the Torx screws with allen bolts
Last edit: 13 years 8 months ago by Dave cc.
  • Dave cc
13 years 8 months ago - 13 years 8 months ago #64246 by Dave cc
Replied by Dave cc on topic Step by step Isuzu diesel conversion
As you can see from the picture the compressor housing points downwards and if not rotated gets in the way of just about everything
  • Beano
13 years 8 months ago #64263 by Beano
Replied by Beano on topic Step by step Isuzu diesel conversion
I love reading about your projects! Keep up the great work mate, you are living the dream for the diesel jims! B)
  • JivingDaddy
13 years 8 months ago #64268 by JivingDaddy
Replied by JivingDaddy on topic Step by step Isuzu diesel conversion
A braver man than me Gunga Din (or should that be Bunged Itin? :-))
  • Smoggy
13 years 8 months ago #64272 by Smoggy
Replied by Smoggy on topic Step by step Isuzu diesel conversion
Many thanks for doing this thread Dave. I will be having a go soon myself
  • Sponnie
13 years 8 months ago #64292 by Sponnie
Replied by Sponnie on topic Re: Step by step Isuzu diesel conversion
Nice one Dave, its on my to do list after the lockers. Keep up the good work.
Sent from my GT-I9300 using Tapatalk 2
Time to create page: 0.124 seconds
