Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
From Jimny to Willys Jeep - Part 4
 George is progressing well with his build. The floorpan and rear sections are complete.
  14138 Hits
Tags:
From Jimny to Willys Jeep - Part 3
 George has sent in a couple more pictures showing the join in the body tub where it was extended to fit the Jimny chassis
  35010 Hits
Tags:
From Jimny to Willys Jeep - Part 2
A further update from George on his Jimny to Willys Jeep conversion.
The "genuine" Willy's Jeep tub has turned up (they are still being manufactured by one of the original licensed Jeep manufacturers in Belgium so its a "New Old" tub)
As you can see in the picture below the chassis is longer than the tub. In the UK the law is pretty flexible around what you can do to a vehicle without having to jump through paperwork and engineering hoops. However, the "certification" and identity of a vehicle is considered to remain with the chassis, therefore chassis modifications (cutting etc.) are more difficult to get approved. Therefore the easiest option is to extend the body.
  15805 Hits
Tags:
From Jimny to Willys Jeep - Part 1
Processed-IMG_20190605_1145021
Sick and tired of your Jimny being called a Jeep?  If so then why not make it a Jeep! George Atkins has kindly sent in pictures of his build in progress........
  9657 Hits
Tags:
New exhaust
Resized_IMGP2520
The exhaust on the Jimny was beginning to look a bit tired. It was not actually blowing but layers of rust were peeling off. Its been on the car from new (2003) and now we are in 2019 so around 16 years old and 24,000 miles (low miles but most off-road). I wanted a stainless steel exhaust and one that is road legal (ie. 74dB at the required re...
  8299 Hits
Tags:
