Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
17/02/08 - Jimny Lean!
A common problem with a lifted Jimny is "Jimny Lean". This is where it appears to sag on the driver side. The original manufacturers springs are stiffer on the drivers side but most lift kits do not cater for this.
One simple answer is to put a spring spacer in on the drivers side. These are available from "Bits4Vits" in the UK. Here are some pictures of mine.
  12502 Hits
31/12/07 - Dennis' Jimny - UPDATED!
Dennis has sent in some new pictures of some extreme green laning! Looks like it might have needed a bit more than T-Cut to clean it afterwards.
  10524 Hits
05/02/08 - Oxley's Shaw
Thames Valley 4x4's February event was at the club's home site of Oxley's Shaw. Following the recent rain the site was the wettest its ever been, with simple muddy tracks seeing every scrabbling for grip.
The Jimny, with its relatively light weight and fat tyres struggled for grip. Instead of cutting through the mud to the grip below it floated on the muddy surface and ground to a wheelspinning halt.
These conditions really needed tall thin tyres in order to be successful.
  9750 Hits
Oh No ! - Where has the metal gone !
So in fitting the front winch I have been looking for a location for the second battery. Playing around with a battery showed that there is not really enough space under the bonnet. The problem is height rather than length. Anyway, the rear tray in the boot is an attractive location for the battery and it puts more weight over the rear wheels.
My car was converted to take a rear winch and this was fitted in the rear tray with a hole for the cable exit. This was letting water in now that the winch is not fitted so in order to fit the battery I needed to fill the hole.......
  9662 Hits
Changing the Brake Pads
We had abandoned our trip to the TV4x4 Club day at Speen due to a horrible grinding noise that could be heard and felt through the brake pedal. The usual reason for this is the front pads are worn. So here is a simple guide to this straight forward job.
  10126 Hits
