M16A non-VVT injectors
1 year 1 month ago #262304
by CB1289
M16A non-VVT injectors was created by CB1289
Ayup everyone!
Just done a swap from m13a to m16a non-VVT on my 2001 jimny. The engine is running, however it's running a bit rough and we think it has come down to the injectors.
The old ones might be shot anyway, so going to order some new ones regardless.
Has anyone got any advice on which ones are best to use and potentially recommend any to purchase?
Cheers
Chad
Cheers
Chad
1 year 1 month ago #262345
by Motacilla
Replied by Motacilla on topic M16A non-VVT injectors
I am bumping your message to the top to see if one of the experts can answer it.
For my part, I rarely replace injectors on a petrol engine; it is usually enough to have them cleaned & tested unless they have done intergalactic mileage. But Suzi units might be cheap enough that it is not worth having this done, I don't know. (But someone here will know!)
- Thank you received: 706
1 year 1 month ago #262347
Replied by jackonlyjack on topic M16A non-VVT injectors
I have blue swift sport ones in my 2004
1 year 1 month ago #262352
by Busta
Replied by Busta on topic M16A non-VVT injectors
You should be using the 1.6 injectors. How long has it run for since the swap?
The ecu has a learning function and after an engine swap it can take time to adjust to the different fuel requirements. I've had some that do it straight away and others that take half an hour before they run smoothly.
Getting the injectors tested and cleaned is your next option. For replacements, any from another M16a or M15a Suzuki will do the job. New will be expensive.
1 year 4 weeks ago - 1 year 4 weeks ago #262372
Replied by yakuza on topic M16A non-VVT injectors
My m16a injectors are yellow, most of them are I think.
Last edit: 1 year 4 weeks ago by yakuza.
1 year 4 weeks ago #262374
by CB1289
Replied by CB1289 on topic M16A non-VVT injectors
Thanks all!
Time to create page: 0.099 seconds
