17/02/08 - Jimny Lean!
A common problem with a lifted Jimny is "Jimny Lean". This is where it appears to sag on the driver side. The original manufacturers springs are stiffer on the drivers side but most lift kits do not cater for this.
One simple answer is to put a spring spacer in on the drivers side. These are available from "Bits4Vits" in the UK. Here are some pictures of mine.
Â
