Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
24/7/08 - MOT Failure
So it never rains but it pours!
 Having rebuilt the entire rear end (trailing arm bushes) and replaced the front shock absorber rubbers I put it in for an MOT.
The failure list was extensive:
Front sidelight bulb - it was working when I tested it
Front nearside kingpin bearing - fair cop it was worse than I thought
Front offside Kingpin bearing - again worse than I thought
Front nearside wheel bearing - looked fine to me but now its in bits I can hear the noise
Brake imbalance at the rear - going to be hard to find as the brakes are all new.
But strangest of all - Roll Cage!
Having passed the MOT in the last few years the Roll Cage managed to fail on "obscuring Area A on the windscreen"
  9462 Hits
20/07/08 - Springs
If you look on the forums there is a bit of discussion about whether springs are "handed". The following information is from the manual....
  10728 Hits
Tags:
20/7/08 - Shock Absorber Rubbers
Will I ever get back off-roading!
  9058 Hits
19/7/08 - Rebuilding the Trailing Arms
You will have read the article (HERE) about the problems I found with my trailing arms - so now on with the story of how to refurbish them.
Replacement bushes are available from Suzuki, for each trailing arm you require two axle end bushes and one body end bush.
The part numbers are:
Axle end: - 42682-81A00
Body end:- 46213-65D00
Be aware that originally Suzuki would only supply the complete trailing arm, they would not supply the bushes separately. Some dealers still think this is the case, simply quote the bush part numbers to them!
The picture below shows the new bushes. As you can see they are encased in a steel sleeve which is a real pain when it comes to pushing the old ones out.
  9766 Hits
15/07/08 - Daves Jimny
Those of you who are regular to this site wil recognise this one. Originally posted here as "Madmicks" Jimny it has been sold to Dave and moved north of the border to Scotland. Dave has added in some more pictures as well.  Its a year 2000 model with:
  15221 Hits
