Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
12/12/09 - Kevin Williams' Jimny
Kevin has sent in some pictures of his modified soft-top
  9471 Hits
29/11/09 - Fitting SJ manual hubs
I have just made up some prototype parts that will enable you to fit SJ manual hubs to your Jimny, overcoming the issues with the Vacuum hubs. This kit will shortly be available to purchase in the shop. In the meantim, here is the guide so that you can start planning the fitting.
  9822 Hits
20/11/09 - Indicator UPDATE
Just an update...
  9060 Hits
17/11/09 - Indicator failure
So I went out today to collect some plywood for the boat (the roll cage makes an excellent roofrack!) and noticed when turning that all four indicators flashed. It doesn't matter which way you turn they all flash together. Fortunately the workshop manual is quite good and goes through a diagnostic to determine whats wrong and it diagnosed that the flasher relay has failed. Its marked up as a DENSO 065500-5350 flasher unit, Suzuki part 38610-84F00. A search of the Internet brought up nothing I can buy (unless I want it in lots of 100!) so its off to the Suzuki dealers (and I bet its not a cheap item!)
  9221 Hits
15/11/09 - CV problems
Folowing a busted CV joint - see Busted  I have spent the last couple of evenings fitting it.
  9767 Hits
