Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
11/03/10 - Gionni's Jimny
Gionni from Italy has sent in pictures of his Jimny
  11072 Hits
07/03/10 - Nellies Dell
So with it being the first Sunday of the month it was off to Nellies Dell. As always it's been a bit touch and go whether we would be able to go. The replacement (updated design) axle shaft retainers from Muddyzook appeared at the end of last week and had to be fitted before I could go anywhere as my use of the hub backing plate was causing problems. However, I decided that one of the rear wheel bearings needed to be replaced whilst I had it all in bits so I did that as well.
  9684 Hits
03/03/10 - Next outing
I managed to get the new axle retainers and replacement brake pads fitted to BigJimny last night (an updated article on fitting the rear disks will follow soon). Therefore we are ready for the Thames Valley 4x4 event this weekend at Nellies Dell, Hampshire - see DETAILS HERE - Does anyone else in the south feel like coming along?
  9110 Hits
27/01/10 - Eating parts
The car seems to be "eating" parts. The table below shows the trail of expense!.
  10823 Hits
24/02/10 - Tie-rod end - UPDATE
So having changed the Tie-Rod end (expensively !!) I took the Jimny down to have the wheels aligned.
  10180 Hits
