Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
27/10/09 - Winch Remote
I found these wireless winch remote kit on Ebay from a company called "Winch-It", they seem to have a collection of reasonably priced accessories.
The dual control wireless remote will enable both myself and James (the co-driver!) to operate the winch in a number of situations. Often the person outside the car has a better  view of the winch situation so, although I already have dashboard switches fitted, this will give extra capability (and its a bit of a show off as well!)
  9306 Hits
23/10/09 - More Jimny Wobble
There is a fair bit of information around about the Jimny "Death Wobble". Followers of this website will know that I am a firm believer in sorting out the Kingpin Bearings and Wheel Bearings as a main source of problems with wobble. However, this is not the complete cure in some cases. I know from other websites that people have rebuilt the front end of their cars and yet still suffer from wobble. This has reached the point where Suzuki have brought out a kit to help reduce the problem. Suzuki apparantly say that the Jimny was designed for small wheels and that larger wheels change the loading on the bearings and result in "harmonic wobble". This is partially born out by the number of instances of wobble in Jimny "O2" variants - with large factory fitted alloy wheels. Suzuki has now brought out a kit for vehicles affected by this and (as only Suzuki can) charge a fortune for it.....
  15439 Hits
23/10/09 - Check your oils!
We are off to the TV4x4 Children in Need event at Broxhead Common next weekend (is anyone else coming?).
  9482 Hits
6/10/09 - Phil Baileys Drum brake tips
Phil has sent in some more of his tips, this time regarding the drum brakes...
  8795 Hits
5/10/09 - Fixing a vacuum hub in the field
A common problem in "Jimnyworld" is to travel to an off-road event only to find that you cannot select 4WD. Either the hubs are stuck or the vacuum has "escaped". For more details on the hubs see my "How to guide"
  18697 Hits
