Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
08/11/09 - Iains' Jimny
Iain has sent in some pictures of his Jimny and I challenge any of the UK readers not to be jealous of the location - The Alps - not sure my Jimny would get to the Alps.
  9950 Hits
3/11/09 - Busted!!
So following Broxhead I had to find out what happened to the 4WD. The main culprit is likely to be the CV joint so I stripped down the hub.
  10141 Hits
01/11/09 - Broxhead Common
Well not such a good day out. It poured with rain at Broxhead today and we got soaked through. Very quickly after arriving we were going to climb a hill in the mud run when there was a bang from underneath and we lost 4WD. Once we had winched out a quick inspection showed that the drivers side front wheel rotates happily on its own, so either the halfshaft has snapped or the CV joint has failed. I would put money on the CV joint as this is the weakest part and the steering gets very stiff on full right lock. I unbolted the freewheeling hub to ensure nothing could jam and we drove home very carefully!!! Also disappointing were the brakes, they were extremelt spongy and the handbrake was very poor. I guess I still have some work to do somewhere on the brake conversion.
  9628 Hits
29/10/09 - Barry (Baz) Harpers Jimny
Barry Harper has sent in pictures of his Jimny.
  10935 Hits
28/10/09 - Jamie's Jimny UPDATED
Jamie Crossley is about to lift his 2007 Jimny. He has sent in a few pictures to show the "before" state of the Jimny. Of particular interest in these pictures is the different chassis ends on the later Jimnys visible in the pictures. It has Maxxis Trepador 250/75/15 tyres on it and re-inforced transfer box mounts.
Watch this space for the lift to occur!
  17297 Hits
