Subcategories from this category:
Old Man Emu vs Des Sol
New tyres
regal2250_IMG_20171106_155451
My new tyres arrived today. Maxxis Bighorn 235/85R16 which I put onto a set of Grand Vitara 16" Deep dish rims. Polish guy down the road popped them on for cash in hand. Looks like I might have to strengthen things in order to turn them :)
  9821 Hits
Tags:
Corrected Rear Arms
jimny_IMG_20171017_191842
If you look around the internet, there is a lot of advice and conversation around castor correction for the front radius arms following a spring lift. However there is a lot less discussed about rear axle correction. Clearly "castor correction" does not apply to the rear but there is still an adverse effect due to a spring lift. There are two main effects, the nose of the differential is at the wrong angle which increases the angles the propshaft has to cope with and the spring mounts are not aligned top and bottom resulting in "banana" springs.
  7732 Hits
Tags:
Fitting rear bump stops
JimnyIMG_20171012_183031
The key to a good suspension set up is balance and stability. Over stretching in any direction achieves very little. Ok so the vehicle may seem to have amazing "articulation" but if the tyres are not generating traction (ie pressing on the ground) it does not matter how far they have stretched to touch the ground. Bump stops are a way of protecting the suspension from over compression on one side and the tyres from rubbing inside the wheel arch. Therefore, with a new set of springs and shock I also have gone for bump stop extensions
  8469 Hits
More parts
jimny_IMG_20171006_190403
I am sure I accidentally sold the shock absorbers I had put aside for my refresh of the suspension on BigJimny. Therefore I ordered a new set plus a set of bump stop extenders for the front. Now to get around to putting them on before I sell them again :)
  6683 Hits
Tags:
Kingpin Bearings - The Video
As my "How-to" guide is really out of date, I decided to create a video of this last weekends Kingpin bearing change on "LittleJimny" before it goes off to its new owner. This is the way, whether you like it or not, that I change the Kingpin bearings....
  13681 Hits
Tags:
