Sunglasses holder help
- BASE 1388
28 Jun 2025 21:29 #261073
by BASE 1388
Sunglasses holder help was created by BASE 1388
Hi all.
I have a VW T6. I have removed the grab handles passenger and drivers side and replaced with a flip down sunglasses holder. The driver side didn’t have a grab handle. ( same as our 2020 gen4. Doesn’t)! But there was a grab handle bracket available to be fitted bought through some vag supplies. I removed head liner and fitted !
can anyone advise if this is possible with the Jimmy and point be in the right direction please
many thanks Romany
many thanks Romany
- Thank you received: 2005
29 Jun 2025 05:18 #261075
Replied by Lambert on topic Sunglasses holder help
My 2024 has upper grab handles on both sides so I would suspect that the mounting is probably there on all shells.
The following user(s) said Thank You: BASE 1388
29 Jun 2025 06:44 #261076
Replied by Soeley on topic Sunglasses holder help
If I remember correctly, the mounting hardware is not there on my 2019 SZ5. I think Martin also confirmed this later on?
I wanted to do the same thing.
The following user(s) said Thank You: Lambert, BASE 1388
29 Jun 2025 07:01 #261077
That's odd. You would have thought that being available in left and right hand drive it would be something on all shells even if they didn't necessarily fit the actual handle?
29 Jun 2025 08:18 - 29 Jun 2025 08:19 #261078
Exactly, it must be easier to leave stuff like that on for LH/RH drive variants. Unless they are taking weight saving very seriously!
Last edit: 29 Jun 2025 08:19 by Soeley.
- BASE 1388
30 Jun 2025 18:16 #261087
by BASE 1388
Replied by BASE 1388 on topic Sunglasses holder help
I’ve had a poke about and can not feel a bracket under the headliner. It’s all soft ! Lol
Time to create page: 0.178 seconds
