2012 Jimny Death wobble, light steering and loss of control
02 Nov 2026 16:41 #265520 by frikki_klausen
 Hi everyone,I own a 2012 Suzuki Jimny JB43 that has some problemsThe vehicle has the following modifications:
  • 2" Black Raptor suspension lift
  • 1" body lift
  • Lowered front suspension arms
  • Upgraded rear panhard rod
  • Black Raptor steering damper
  • 31x10.5R15 tyres on 10" wide steel wheels
Recently replaced front-end components:
  • 4 kingpin bearings
  • Kingpins
  • Preload shims
  • 2 track rod ends
  • 4 steering rod ends
  • Front panhard rod bushes
  • Anti-roll bar bushes
Current steering issues:
  • Steering wobble occurs at approximately 60–80 km/h.
  • The steering feels extremely light at about 40 - 100kmh.
  • There is some play in the steering before the wheels respond.
  • The vehicle has spun 180 degrees while driving a couple times and it frequently feels like it is about to do it again.
The steering wobble is still present despite replacing the components listed above.My questions:
  1. Could the very light steering and large dead zone be related to the steering box?
  2. Would 5-degree caster correction bushes help restore steering feel and stability?
  3. What else should I inspect, particularly regarding the front axle, wheel bearings, steering box and suspension geometry?
I would really appreciate advice from anyone who has experienced similar problems with a lifted JB43.Thanks!
03 Nov 2026 05:35 #265521 by yakuza
Wobble is caused by the sum of all play in the steering components but can be induced or set off by a number of things. 31" is a bit much so only small play or small clearance can make for large symptoms. A slight more toe-in can help, from memory I had 1 degree more than spec. And castor correction bushes or arms. 5 degrees is a bit much on a 2" lift though (from memory). 3 degrees or so should be more correct. All lifts should be checked for the need of castor correction. Here in Norway you will no get your lift or lowering approved without a full check of your wheel geometry and alignement and a print out from the alignement machine.
Steering boxes are prone to getting more play also from the wobble and from time and use. They can be adjusted carefully and tightened but often they are most worn in the middle and less at full right/left so make sure not to overtighten them. Rod ends, wheel balancing, kingpin shims for the correct load on the bearings, many things can make a difference. Hard old rubber on those tyres? as you loose control so easily? most problems on wet roads?
Time to create page: 0.138 seconds
