Re:DrRobin's Northumberland Jimny
05 Nov 2024 21:51 #258198 by jlines
Probably best to have a bridle or strap already attached if it's likely you will get stuck. Although securing high up on a standard car may be difficult as I've seen plenty come off and end up getting wrapped around the wheels.
  • DrRobin
  • Platinum Member
  • Platinum Member
  • Newbie in Northumberland
06 Nov 2024 10:10 #258201 by DrRobin
Thanks James, I thought about doing just that and tie the bridle up on the front bumper, but apart from a lack of suitable mounting points I was worried it might get snagged on something and put undue strain on the bumper.
I suppose I could get a short fabric strop and just extend one recovery point to just above the bumper, that would be fairly easy to secure with some shock cord.
Robin
  • DrRobin
  • Platinum Member
  • Platinum Member
06 Nov 2024 12:56 #258203 by DrRobin
I fitted a Jimnybits transfer case cover today.
It was fairly straightforward but the two bolts which pass through the frame/transfer case mounts weren’t the easiest to locate and tighten.
i only have the rear diff to do now, but that is back in my paint shed for a final coat.
Robin
  • DrRobin
  • Platinum Member
  • Platinum Member
06 Nov 2024 13:49 #258205 by DrRobin
I found a 550mm long soft shackle from Terrafirma, that might do the job
terrafirma4x4.com/tf3310xl.html
Available on eBay at £23 each.
  • DrRobin
  • Platinum Member
  • Platinum Member
08 Nov 2024 21:14 #258233 by DrRobin
The final part of my Reeth to Ripon tour, this time it is Arkleside, Dead Man's Hill, Scar Reservoir and In Moor Lane.
I go on a two day trip over the weekend, Stokesley to Reeth, no doubt more video reports will be on their way.
Robin
The following user(s) said Thank You: Lambert, gv42, Soeley
  • DrRobin
  • Platinum Member
  • Platinum Member
10 Nov 2024 21:52 #258253 by DrRobin
Another good weekend on the lanes with Trails and Tracks, this time N. Yorkshire Moors and another ‘Pot of Gold’ for my Jimny.
Then day 2 in the Yorkshire Dales and another go at Fremington Edge.
Robin
The following user(s) said Thank You: gv42, Soeley
  • DrRobin
  • Platinum Member
  • Platinum Member
12 Nov 2024 22:36 - 12 Nov 2024 22:38 #258281 by DrRobin
So I bought some shock cord loops and threaded them through the front grille support (it’s metal) and these hold the bridle in place.
The shock cord loops tuck in to the grille and won’t be noticed so I will leave them in place and just fit the bridle when required.
If the bridle catches on anything it will just pull out of the shock cord and won’t do any damage.
Robin
Last edit: 12 Nov 2024 22:38 by DrRobin.
  • DrRobin
  • Platinum Member
  • Platinum Member
12 Nov 2024 22:54 #258282 by DrRobin
As seen at Bedale services
One is capable of some extraordinary things and the other is a fast jet.
Robin
The following user(s) said Thank You: yakuza, gv42, Soeley
